Question about Gigabyte GA-965GM-S2 Motherboard
New Crucial 2x2GB modules not working on boot-up
Just bought a new 4GB set from Crucial UK (from automatic recommeneded upgrade tool).- 2x 2GB http://www.crucial.com/uk/store/mpartspecs.aspx?mtbpoid=ABDCB14BA5CA7304 Currently got 2x 1GB Ballistix. Only either ONE of the new 2GB modules will work by itself without any other of the aforementioned modules. But when both new modules, or any other combination are put in together, the machine will not boot. Have tried everything / all combinations but am absolutely stumped on this one. PC will work as normal when Ballistix modules are put back in into their original state. Any help much-appreciated
2 Suggested Answers
yboyandrei
  • 828 Answers
SOURCE: Too much memory for Giga-Byte K8M800-8237
The issue of this is not too much capacity on your memory., i tell you the problem is incompatible both of them. Check again your memory and what brand are there.
Because something motherboard settings are being notify if reliable to you to use different kind of RAM you have. Read the motherboard manual to find out some settings to enable both of them are not the same brand or model.
Posted on Aug 03, 2009
How do I add RAM to a Lenovo ideapad 320?
Lenovo IdeaPad 320-14AST compatible upgrades These upgrades are guaranteed compatible when you order from Crucial.com
http://uk.crucial.com/gbr/en/compatible-upgrade-for/Lenovo/ideapad-320-14ast
Does this one work (it lists several thinkpads but not the e320)?
http://www.elive.co.nz/kingston-4gb-ddr3-1333mhz-t17327.php
Jul 17, 2017 | Lenovo Computers & Internet
What is the difference between E & P on 6400E SDRAM and 6400P SDRAM
"P" stands for "parity" and "E" stands for ECC (Error Checking & Correcting)
To determine which memory modules will work in your PC, visit the Crucial web site at: www.crucial.com and use their memory selection software. You will have to allow the site to scan your system.
Oct 05, 2015 | HP Computers & Internet
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
I want to add 4GB of DDR3 memory, what further info to I need to know about the memory?
Newegg has a great site to find the correct and most compatible memory for you Here.
To maximize your ram speed, use the same speed and types of ram
For example, if you have a 1GB right now, add three more 1GB than putting in a 2GB and 1GB.
If you have a 4GB ram stick right now, add another 4GB and not 2x2GB. Also make sure the MHz on the ram is the same, (1333, 1600, 2000)
Enjoy upgrading your computer!
Mar 06, 2011 | Acer AM3400U2502 PC Desktop
What is the optium ram upgrade for a lenovo 3000 y410
DDR2-PC5300, and the max it will accommodate is 2GB (2 x 1GB).
Hope this helps you
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
I FOUND 1 MEMORY SLOT
Hi there.
The memory slots are more or less on top of each other.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Acer Aspire 4315 Notebook
Toshiba m105-s3084
Number of Slots:
Slot 1 Slot 2 Normally you will find the 2 slots, one above the other.
Each memory slot can hold DDR2 PC2-5300,DDR2 PC2-4200 with a maximum of 2GB per slot.*
*Not to exceed manufacturer supported memory. Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules. Make sure that both are fully seated prior to powering up the laptop.
Nov 05, 2008 | Computers & Internet
System failed to boot when installing additional 2X 1GB RAMs.
you need to place them on your motherboard where the memory is installed. Place in the order of one new, one old, one new, one old stick. that way they run in dual channel.
Oct 07, 2008 | ASUS M2N-E SLi Motherboard
Gigabyte GA-965GM-S2 Motherboard Logo
69 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
