Question about HP Office Equipment & Supplies
Hp color laser jet cp1515n error 53.23 - HP Office Equipment & Supplies
Joed911
  • 4338 Answers
SOURCE: My HP color laser jet
This is what HP says about error 49:
Control Panel Message:
49.XX.XX
PRINTER ERROR
To continue
turn off then on
Description:
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt
data during transmission to the printer.
Other causes include poor-quality parallel
cables, poor-connections, or home-grown
programs. On rare occasions, the formatter
is at fault, which is usually indicated by a 79 Service Error.
Recommended Action:
1. Turn the printer off then on.
2. Press Stop to clear the print job from
the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
displays only with a certain software
program or print job, contact the
software vendor for assistance.
5. If the message persists with different
software programs and print jobs,
disconnect all of the cables to the
printer that connect it to the network or
computer.
6. Turn the printer off.
7. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM.)
8. Remove all EIO devices from the
printer.
9. Turn the printer on.
10. If the error no longer exists, install
each DIMM and EIO device one at a
time, making sure to turn the printer
off and on again as you install each
device.
11. Replace a DIMM or EIO device if you
determine that it causes the error.
12. Remember to reconnect all of the
cables that connect the printer to the
network or computer.
13. If the error persists, upgrade the
firmware compact flash card.
14. Replace the formatter and calibrate
the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 11, 2008
  • 327 Answers
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Posted on Dec 15, 2008
SOURCE: Our HP Color Laser Jet Printer keeps saying 50.2
I had a similar problem. make sure the fuser is the same voltage as the printer. 110v printer needs a 110v fuser. easy way to tell. White barcode sticker it is a 110v. Red or Pink then it is a 220v.
Posted on Aug 27, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
  • 6 Answers
SOURCE: HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
My laser color HP cp1515n is not copy anything that's black copy? what can l do
Hi there, my name is Lisa and I'd be happy to help you with your LaserJet CP1515n. The following document will help you to troubleshoot the issue you have described:
HP Color LaserJet CP1215 CP1217 CP1514n CP1515n and CP1518ni Printers One...
I took a second look and found this one too:
HP Color LaserJet CP1514n CP1515n and CP1518ni Printers Resolving Print...
I hope this helps.
I work on behalf of HP.
Jun 19, 2015 | HP LaserJet CP1515n Printer
Hp color laser jet 5550dn shows error code 10.10.02 supply memory error
This error codes indicates that one of the toner cartridges you have installed does not contain a valid chip on it. If you recently changed a cartridge that is the likely culprit.
Feb 28, 2015 | HP Color LaserJet 5550dn Q3715A Workgroup...
Why givethe Hp color laser jet cp1515n 51.23 error massage
Hi
I found this message regarding your error
Display: 51.XX Error
Description: The product has experienced an internal hardware error
Remedy: Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize. If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product on.
You can also find it here:
Error Codes HP Color LaserJet CP1515 Code 51 XX
and by using the drop down menus you can find details on other errors and also other models and makes. There is also a link to get a pdf format Service Manual which may be useful to you in the future.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | HP Office Equipment & Supplies
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
What is the 59 CO error?
59.C0 Developer motor rotation error
1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
2. If the problem continues, contact HP Customer Support Center for technical assistance
Sep 09, 2014 | HP CC377AABU Color Laserjet Cp1515n...
HP Color LaserJet CP1515n Printer is showing error 51.23. please help
error 51.23 on the hp color laserjet cp1515n printer. please help
Apr 28, 2011 | HP Office Equipment & Supplies
Cannot find driver HP cp 1515 laser jet...
For older versions of Windows (98+ME), try the HP Color LaserJet 5/5M PS 9X driver - it works for me on ME on a CP1514N
Dec 03, 2009 | HP LaserJet CP1515n Printer
Seeker5211
Seeker5211
