Question about Craftsman Garden
Pto on yardman 42 lnch cut belt will not go tight
Loose belt pto not keeping belt tight
    Problem Solver:
  • 12 Answers
A spring keeps the tension on a PTO belt. It may be broke or unhooked.
Posted on Jan 16, 2013
  • 27 Answers
Looks like the manual is now longer available in the link above. So, just in case, you can download this MTD Yard Man 42" Mower.
Posted on Feb 02, 2013
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
Posted on Apr 06, 2009
  • 218 Answers
SOURCE: replacing belts on sears lt4000 42 in cut?
Hi..my name is Keith..and you can go to an online lawn mower parts site...and they will have a parts diagram of the deck and drive belt..one if the sites is.. www.outdoordistributors.com ..i hope this will help
Posted on Jul 08, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
  • 16 Answers
SOURCE: how do you tighten lower belt on a 42 ich yardman
By lower belt i suppose you are reffering to the drive belt or the blade deck belt, either way these belts are usually tensioned by a spring loaded idler pulley. If the belt is still too loose even with the pulley tensioning it, it may be time for a new belt (that one may have streched out a bit).
Posted on May 07, 2010
SOURCE: need diagram or instructions on putting on new cutting belt
bex bissell proheat
Posted on May 21, 2009
I have a MTD yardman 1999,2000 ride mower that won't start because it says the pto is engaged when it's not actually engaged if you could comment an image of the same 42 inch deck?
Check your PTO switch operation which is at the engagement handle.
As for hooking the cable spring to deck idler pulley and brake assembly it goes in the hole closest to the idler pulley on the G deck which different then the F deck which uses the same idler arm assembly as the part is design to fit both decks.
Also make sure your using an OEM spec as a will fit will not work properly. You also must the spindle pulleys belt retainer covers in place so the belt will stay on.
May 10, 2015 | Mtd Garden
Disengage the blades on a MTD yardman 42 cut 18Hp
There should be a PTO lever on the right side. Slide back to disengage.
Oct 10, 2014 | Garden
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
I have a 2002 YardMachine, 660 Model, 15.5 HP, 42" Cut. Two Issues. 1) After changing of PTO Cutting Blade Belt, mower lost all power to transmission. No GO F or R. Before belt change, mower would loose...
without looking at the belts i will tell you that the wheels on most mowers only come in a few sizes and are made by just one or two companies. so find a mower or small engine repair shop in the phone book and go get some new wheels and bearings from them. makes it easy if you take an old one with you. while you are there run the belt issue past them and maybe they can give you some guidance.
Oct 18, 2010 | Yard Machines 42" Tractor Mower Blade Kit ...
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
How do you tighten PTO belt?
If the belt is loose it probably needs replaced or has jumped out of one of the pulley or belt guards allowing it to be sloppy. Belts get stretched in many different ways, tall grass, grass getting in the pulley, or they just plain stretch. First though, check to be sure the belt hasn't jumped out of it's normal runway.
Jun 23, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
371 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
