Question about Retail Supplies
What does 'one-line' mean? what is the difference between that and 'two-line' price guns?
  • 103 Answers
One line gun feeds a thinner label that only shows the price. the 2 line gun feeds a wider paper and prints both the price and another line of numbers, usually the date
Posted on Jan 13, 2013
Why doesn't my Arrow fire any staples any more? It's not jammed. The piston doesn't seem to raise high enough to get over the next staple in line. Is it worn out?
Might be could also be that you have the wrong staples in it. Arrow makes about 15 different staple guns. The reason for that is so they can sell you the right for your use staple gun. This also means that certain staples only work for certain guns. Check the model then check arrow web site and find the compatable staples for that gun. Hope this helps
Aug 19, 2014 | Tools & Hardware - Others
I dont know what ''line'' means on clubpenguin book codes
It means like if you write a line like this
line 2
line 3
line 4
like that
Mar 27, 2013 | clubpenguin.com
Senco nail gun sfn30 is only firing every second nail in
You have damaged o-rings in the gun. Remove the head cap & valve assembly, remove the ring on top of the cylinder, remove the cylinder & piston. The cylinder is in tight so work it out carefully. Check the condition of the following: a split flat ring with a rubber o-ring under it on the top of the piston and two o-rings on the outside of the cylinder. If these are damaged air will leak around the piston instead of pushing it back up. The inside of the gun should be clean with a light coat of oil on everything if you are oiling it properly before use. Dirt in the gun means the gun is being laid on the ground without the air hose attached. Dry innards means no or not enough oil is being put in the gun before use. Oil pooled in the bottom of the gun means too much oil is being used. Senco doesn't make a rebuild kit for this gun, you'll have to go to the Senco website http://www.senco.com/ or other website like http://www.ereplacementparts.com to get a parts breakdown of your gun and order the o-rings (any part beginning with LB) individually. If you replace one, replace all of them and grease them up liberally when reassembling the gun.
Jan 29, 2012 | Senco Tools & Hardware - Others
This is for the kx-ta824. I am trying to add 82470 extension card to get 32 extensions.
That would be a trick. 824 means 8 lines and 24 extensions. An 82470 fits in one of the 2 remaining slots of the 824 system and it has no lines and 8 extensions. For the price, it's a pretty worthless card, as it will have no resale value. I think the price difference between an 82470 and an 82483 (3x8) is about $100 and maybe $50 more than an 82481 (2x8).
Carl
Aug 25, 2011 | Panasonic KX-T7730 Corded Phone
Monarch paxar 1110 pricing gun brand new. The box was thrown away and it isn't working. The label prints out without a price the ink is fine we tried it on a different gun. Any trouble shooting ideas??
Here's a video that shows how to properly load supplies into the gun. It's possible that the supplies aren't loaded properly..
http://www.racoindustries.com/monarch-1130-1131-1136-labeler-loading-video.htm
Dec 27, 2010 | Paxar Monarch 9825 Thermal Label Printer
Whats the difference between jl audio 500.1 amp & jl audio 500/1v2? why is the price range so different?
500/1 is JL upper line, and the 500.1 is their lower line. They also have another line altogether that is under a different brand name.
Sep 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
PARTS
go on line with the brand of the machin
Mar 18, 2009 | Firepower 120 Amp MIG/FLUX Cored Welding...
General interest
Purchased the Northern Industrial Dual Temperature Heat Gun Kit - Model# RP2049K Instead
Price
$27.99
332049_med.jpg 332049 FREE SHIPPING — Northern Industrial Dual Temperature Heat Gun Kit - Model# RP2049K
Dec 16, 2008 | Pro Line 10 Pc. Proline Heat Gun Kit In...
Retail Supplies Logo
338 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
