Question about Garden
Blade bolt torque for castle garden lawnmower
What is the blade bolt torque to sequre the blade to the alloy blade driver?
2 Suggested Answers
num1wrench
  • 14 Answers
SOURCE: which way do you turn the bolt to remove blades on
Turn to the left.....while holding the blades still....If it is hard to do, then use a wrench and beat it with a hammer...or use and air impact wrench.
Posted on May 10, 2009
Where can I purchase blade bolt set CA09164 and felt caps and washer set CA09028S for old toe cutter victa lawnmower?
i am sure that the bolts come with the blades as sets and there hasn't been a change since victa started
Talk with a mower shop as they have a selection of bolts and kits
Mar 29, 2017 | Garden
Castle garden lawnmower won't start no park plenty oil in the engine
go to google and type in what you are trying to do. google will let you know via video step by step what to do to fix your problem
Mar 15, 2017 | Garden
WHAT ARE THE TORQUE SPECS FOR A 17.5 hp BRIGGS @ STRATTON ENG
What are you torquing the bolts on the bottom that hold the blades? If it's the bolt on the blade that fits under the deck on the hub it's 65lbs don't over tighten or you will break off the bolt. Sorry if that was not the answer to your question maybe be more specific. MJ
Sep 30, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade will not disengage on Craftsman GCV160 lawn mower.
that type mower the blade always turns when running .
May 07, 2015 | Craftsman Garden
Castle garden lride on lawn mower engine cuts out when I turn on blade
if your saying engine dies when you engage blade need to adjust the carb rpm
Sep 20, 2014 | Garden
Change blade on gas lawnmower
varies slightly as u didnt give model, i run front wheels onto car ramps and block rear wheels, then in middle of blade is a large bolt hold blade with leather glove and unscrew, put new one on and tighten,
Jun 09, 2012 | Craftsman Garden
I have a Brute by Briggs Stratton 21hp driveable lawnmower. How do you change the blades?
JUST RAISE THE MOWER TO HIGHEST POSITON TO ALLOW YOU ACCESS TO BLADES
REMOVE BOLT AND BLADE AND INSTALL NEW OR SHARPENED BLADE
ENSURE IGNITION SWITCH IS OF
Sep 02, 2011 | Briggs & Stratton Garden
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Which way do you turn the bolt to remove blades on a yardmachine 38" riding lawnmower deck. Its a 12.5 hp motor and has 2 blades on the deck.
May 10, 2009 | Garden
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Mar 28, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
