Question about Maytag Washing Machines
Maytag LAT8826AAE agitates but won't spin. I have replaced both belts still smells like burning rubber.
I have replaced both belts still smI have replaced both belts still smells like burning rubber.
the dr
  • 447 Answers
SOURCE: Maytag washer
lean the washer back .......
Posted on Oct 07, 2007
  • 15 Answers
SOURCE: Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Posted on Oct 10, 2007
docjohn174
  • 943 Answers
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
  • 13 Answers
SOURCE: whirlpool top loader won't spin
If you are lucky you need a set of clutches about $45. If you are unlucky you would need a transmission.
Since it spins after you help it, I am guessing clutches.
Posted on Feb 24, 2009
mindreader
  • 578 Answers
SOURCE: The Maytag washer doesn't spin and had a burning
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Posted on Oct 23, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Older topload maytag won't agitate , smells like burning belt
Best to look at replacing belt, but first check to make sure nothing is seized, drum spins freely etc.
Jul 23, 2011 | Washing Machines
I replaced both belts on my washer. Last night I smelled burning rubber. Today the cycle will fill, and spin yet will not agitate. What should I do ?
The pump belt has to be adjusted correctly or the drive belt will slip. If it already slipped enough to burn the new belt, you will probably need another drive belt.
Jan 06, 2010 | Maytag Atlantis MAV5000
My Maytag Performa doesn't work on spin cycle. Burning rubber smell. Belt looks okay. Pumps out rinse water but drum won't spin.
Brakes are locked in the spin cycle or the pinion shaft has dropped down from within the transmission not to engage the agitator.
Nov 05, 2009 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
