Question about HP iPAQ RX3115 Pocket PC
IPaq rx3115 I used my IPaq rx3115 on Wednesday and it worked just fine. I turned it off, put it in its sleeve, and put it down for the night. I did get a message telling me that the battery needed to be charged soon, so I didn't use it for long. The next morning, I attempted to turn the unit on and absolutely nothing happened. Dead. Completely. I plugged it in to the USB cable to charge while I was at work, and upon returning, tried it again. Nothing. It is completely dead. I can't turn it on to do a soft or hard reset. Do I now own a small, expensive doorstop?
  • Kelly Wade Jul 13, 2007
    Ok, got a cradle and tried to charge it that way. The unit lit up, and a bar started crawling across the bottom of the screen. There was also the information "1.01.11A" at the bottom of the screen. As soon as the screen went dim, the bar stopped moving, and the unit is totally unresponsive. I can't do a reset of any kind on it right now. I'm going to let it charge overnight and see what happens. I'll update.
  • Kelly Wade Jul 21, 2007
    Fixed. Battery went nuts for some reason. Replaced battery, all is well! Thanks for your help.
I had a similar experience. My device would not charge via the usb charger so I connected it to my wall charger and it charged successfully.
Posted on Jul 10, 2007
I want to restart of shut down my HP iPAQ rx3115
For the HP iPAQ rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Mar 01, 2011 | Cell Phones
Is the Ipaq RX3115 compatible with Windows Vista?
Yes, but you will need to download Windows Mobile Device Center - free from Microsoft,
which replaces ActiveSync
ActiveSync is not compatible with Vista
Oct 22, 2008 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
HP rx3115 hard reset
Had the same problem with my hp rx3115 . Worked fine, then the next day dead. power button, lower buttons, or outter reset button didn't work to turn it on. Okay so, i thought it just needed to recharge. Used computer cable for active synchronizing that also recharges, still dead. Then cable just for recharging. Finally comes on. Charged it all the way up, synchronized it, unplugged it, few minutes......dead. The battery is no good.
Nov 16, 2007 | HP iPAQ RX3115 Pocket PC
Lost sound
So there's another icon at top of Today screen - a loudspeaker icon - tap on that and make sure it's not muted or all the way down.
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Ipaq rx3115 doesnt turn on!
I am guessing that you have made sure that it is fully charged. If it is, since you have only had it a week I would try a hard reset. I don't know if the 3115 has them but check to make sure that any battery door lock switches are locked.
IPAQ RX3115 Crash
I contacted HP on-line chat and after doing a few tests they advised me to exchange it for another one with the dealer. My second one is working great. I think it might be a Li-Poly battery issue as I deal with similar issues in my business using them.
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
HELP Rx3115 today screen help
Did you try doing a soft reset? Switching off and on again does not reset your ipaq. You will not loose any info.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Storage question for Ipaq
You have too many files in your root folder... Create a subfolder and copy the files into it...
Sep 07, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
166 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
