Question about Retail Supplies
How do plastic bags stay together? - Retail Supplies
    New Friend:
  • 103 Answers
They are usually heat sealed, and sometimes they are stitched together, or an adhesive is used
Posted on Jan 13, 2013
What is the fault when the air bag dash light flashes code 49
It's a common fault on many Fords, usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat. Just push it together properly and it should clear the fault. If not, go under the drivers seat and secure all the wires and clips there as well.
Aug 21, 2014 | 2006 Ford Territory 4.0
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Took bag completely off and now I can't put it back together
Put the outer bag back on the unit. Make sure that you have pushed the outer bag down past a black lip. The piece that holds the inner and outer bag on the vacuum needs to be put on next. The small horseshoe shaped plastic piece goes on with hte open part down. Make sure that the docking station goes behind the lip I told you about. Next put the piece that the inner bag slides into on. This should have the bag back on the vacuum and ensure that it is on properly. If not, then it will pull of pretty easy and blow dirt into the outer bag...not the one that is meant to catch the dirt....I am a manager of an Oreck store.
Dec 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
The motor fell apart and need to put it back together 18volt b&d cordless drill
Get a large plastic bag and put all the pieces in to it. Shake bag for 10 minutes. Look into bag, has drill reassembled? If not, shake again for 20 minutes. If this fail to reassemble drill, throw bag into land fill, and buy a new drill. Thank you for your support of BD.
Sep 10, 2009 | Black & Decker Drills
Oreck xl 9100 bag wont stay on using type cc replaced inside bag hanger
What year model?
Pre-late 1990s, bag on upright just fit over the adapter in the tube.
Lat 1990s, went to a version that had a sliding piece of paper to cloe off the bag & prevent spillage, and required a hinged plastic piece for chipboard piece on bag to slide into.
Must have right bag for the unit, otherwise it will not stay on, will leak.
Jul 22, 2009 | Oreck XL Ultra Bagged Upright Vacuum
2006 Ford F150 ABS light and Air bag light stays on
The usual problem causing the AIR BAG light is a poor connection on the YELLOW CONNECTOR under the passenger seat.
Push it firmly together and that should cure the Air Bag Light
Jun 09, 2009 | 2006 Ford F-150
98 Range rover SE air bags light stays lit
there is is kit that comes together with the coil spring if you buy from landrover dealer, that block out the light. Its a simple socket that you plug into the system.
Jan 15, 2009 | 1998 Land Rover Range Rover
Retail Supplies Logo
785 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
