Question about Optoma New Original SRCT4 Remote Control
Remote optoma src-T4 doen't match any more ? Is there a solution ?
Is there a replacement device available ? Thanks Bernard
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
Optoma EP7155 gets very hot and shuts down.
it could be the fan there are normally more than one, replacement is not hard just make sure you remember how it goes back together, a hint would be to get a digi cam for every part you take out, it may sound silly but very usefull esp when ordering parts, or make sure the lamps was replaced with the right one, if you still have the old one check the code numbers match... good luck
May 15, 2010 | Optoma EP7155 Projector
Drivers download toshiba t4/495cme
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=dynabook&x=0&y=0
Try this link - be careful to match your exact device before downloading any drivers or bios.
May 03, 2009 | Toshiba Computers & Internet
Projector to laptop
Your post:
  • cords/cables - would depend on what are the available OUTputs from your laptop. Some examples are DVI, 15pin VGA, S-Video and the single yellow RCA;
  • where - would depend on where you are, the DVI and/or 15pin VGA cable would be available from most computer shops, the S-Video and the RCA from most electronic, audio/video stores.
  • how to do it - would depend on the brand & model of your laptop. Normally it would be a combination of the Fn key + F? to enable the external video. Cycling through would yield, LCD only, LCD + external, external only. The F? would be dependent on what laptop you have. Connection wise, it would be a matter of connecting the appropriate cable to match the available output connector of the laptop to a matching INput connector of the Optoma projector;
  • Additionally, depending on the model of the Optoma (more specifically its resolution), it may be to your advantage to initially lower the screen resolution and screen refresh rate of the laptop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 20, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 color wheel
Okay, I recently had a loud noise coming from my projector and found online meterial stating that the colour wheel had been damaged. So with a bit of guts I managed to open the projector and found the colour wheel missing a segment.
I removed the colour wheel and the broken piece of the segement and tried to contact Optoma. Optoma turned round and said they cannot sell me the the colour wheel, which got me very upset. Some people claim online that Optoma will sell you the part on a back order at £50. (if you can be a little specific on how you managed to convince them to sell you the part, would be great).
The only option I had available was to send my project to them and they would repair for an estimated cost of £125+VAT. Guess what, you can buy the entire projector off ebay for 150quid!!!
Anyways after fiddling around quite a big online I got fedup and decided to glue the broken segment together and it SOLVED the loud vibration problem. I have colour and picture.
Becareful not to tighten the colour wheel screw too tight orelse it will break another piece of segement (Like I did).
Here are instructions on how to open up the projector.
http://www.geekfest.info/DV10/dv10.html
I cannot guarantee this will work for you as it depends on how badly you have shattered the colour wheel segment, so do at your own risk. I had two piece of the segment broken and a third by tightening the colour wheel screw too tight.
This will work for awhile but the colour wheel does need replaceing one day. If anyone can tell me how you can get Optoma to sell you the colour wheel would be great.
Best of Luck
Aug 08, 2008 | Optoma MovieTime DV10 Multimedia Projector
Bad color wheel on Optoma DV10
Yes, you can replace the color wheel yourself if you are handy with a screwdriver.
Jul 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
May 07, 2008 | Optoma MovieTime DV10 Multimedia Projector
Reading T4 Device
Did you try to boot the system without all the harddisks inside (keep at least one).
This helped me to bring up the NAS-T4 up again.
Mar 04, 2008 | Fastora NAS-T4 Hard Drive Array
Optoma New Original SRCT4 Remote Control Logo
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
