Question about Digi-Tech Digitech Vocalist Live 4 Harmonizer
No mic coming though on vocalist live 4
Just bought the vocalist live 4 My guitar is coming through nice and clean but I can't here any vocals. My leads and mic are all in working order and I have tried many combinations to try and hear some vocals. Also I can only tune the low E on the guitar when using the tuner is there a trick to this as well.. Have you any suggestions that might help me. cheers
  • 110 Answers
Sounds like the mic you are using requires "Phantom Power." This means, you will likely have to purchase an external unit for this power (+48V) power to the unit. I use a Behringer Ultra-Voice Pro for mine. Works great!! You can find these on Ebay at a steal!
Posted on Jan 14, 2013
3 Suggested Answers
SOURCE: Digitech Vocalist Live 4 blead through
I'm having a similar problem with my Sterling audio ST-55 mic and a acoustic guitar. I regenerates the signal and sounds like it's under water. I turned down the mic input knob on the back of the unit until I got a clean sound. The only down downside to this is you have to practically eat the mic.
As for solution #1... Another mic choice will do the trick. But the other technique with putting a wall between your guitar and mic doesn't sound like it would work if you are sitting in front of your digital recorder with a mic in front of you and a guitar in you lap.
Posted on Dec 12, 2009
  • 140 Answers
SOURCE: I have a digi tech
Check to make sure the output jack has not broken away from the circuit board. If not it may have to go back to Digitech.
Posted on Jun 10, 2011
The vocal cuts out completely from time to time. Comes back after a while but keeps cutting out at intervals. Have two of these and both do it. Is it my set up, is it overload in some way. Guitar ok. Use...
The amp or pre-amp for the vocals built into the unit is failing when it gets warm. This is a common problem with electronics, that when it cools down cures itself until it warms up again a few seconds later.
The units need repair or replacement.
Dec 22, 2013 | DIGITECH VOCALIST LIVE 2
Can i run Vocalist live 3 through only an amp? if so how what cables do i need.?
The only guitar amp that has 2 female jacks, one xlr and one 1/4" is a tall Acoustisonic anp by Fender . I have one and I use the Vocalist 3 and I still have an instrument jack for my acoustic guitar . hope this helps .
Sep 18, 2012 | Digi-Tech Digitech Vocalist Live 4...
No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Jan 28, 2012 | Music
Distortion on vocal reproduction on Vocalist Live 2. Even with input volume down to minimum a loud vocal performance produces distortion on single voice and harmony output.
You need to check the actual signal levels to make sure they are within the specs for the unit. The mic input is low impedance. Your mic should be like a Shure SM58 or equivalent. The output is fairly high... up to +14DB which will require you to turn down the trims on a mixer this runs into or set a -20Db pad at the input. I suspect your distortion is from the device output to the mixer input. It is VERY important that the mic does NOT "hear" the speakers as the feedback loop resulting will be mass distortion. The guitar should also not "hear" the mains.
May 07, 2011 | DIGITECH VOCALIST LIVE 2
APX900: Feedback at seemingly normal playing volumes. I've had this problem playing both indoors and at outdoor venues. I use a Fender Passport 250 sound system and run my guitar through a Digitech...
Make sure the passport speakers are NOT where the guitar can hear them... they need to be toward the audience from where you are. Also do NOT boost the high end frequencies with the EQ. That guitar probably has a hot pickup subject to ambient sound. Beyond this, you might have to use one of the feedback destroyers. If you are using monitors, take the guitar out of them.
May 03, 2011 | Yamaha APX900 COMPLETE GUITAR BUNDLE
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
I am getting a fuzzy sound from the vocalist 4 on my guitar, almost like if you strum the strings and forgot you "stored" your pick between the strings.Can you help? Thanks
This MIGHT be typical digitizing noise that can occur with a digital effects processor when the signal level is too LOW. The signal gets down in the noise because it only uses a few bits of data which means LOW resolution in the effects processing.
Make sure your guitar is producing the level required by the vocalist.
Weak battery in amped guitar is common...REMEMBER always send the signal between devices at least at half the max volume to keep a decent signal-to-noise ratio.
ALWAYS use instrument grade cables between the devices and speaker cables for speakers... NEVER use the incorrect ones for either of these functions. They should be labelled.
Dec 26, 2009 | Digi-Tech Digitech Vocalist Live 4...
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
You need a directional microphone, and then it needs to be pointed away from the guitar. Another technique would be to provide some acoustic insulation between the mic and the guitar, like a wall or a partition like what is used to set up office cubicles.
Feb 23, 2009 | Digi-Tech Digitech Vocalist Live 4...
Digi-Tech Digitech Vocalist Live 4 Harmonizer Logo
154 people viewed this question
Top Digi-Tech Music Experts
rjivaro
Ben Armstrong
Are you a Digi-Tech Music Expert? Answer questions, earn points and help others
