Question about Sony Playstation 3 (PS3) Console
Ps3 slim wont take disc you can push it in with no resistance
If you put it half in turn it on holding the on and eject buttons down it gos in but don't read disc but you can eject it ok
  • malcolm matthews Jan 15, 2013
    Got a new drive on the way see how that gos
    Sorted got new drive Swap the boards over now working
    Novelist:
  • 159 Answers
Sounds like a dead laser take to a qualified repairer for repairs.
Posted on Jan 13, 2013
J4XXN
  • 182 Answers
SOURCE: PS3 DRIVE PROBLEM!!! WON"T GRAB DISCS!!!
try holding down the eject button for 10 seconds, it resets the drive, hope this helps
Posted on Feb 17, 2008
bubulica2000
  • 55 Answers
SOURCE: System wont load or eject any discs...
Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
Carefull remove the guide mechanism (the front part -1 screw).
The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
mount back the guide mechanism, and the top part.
Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
That will reset all the gears and stuff.
Worked for me when I experienced that issue.
Posted on Sep 05, 2008
SOURCE: PS3 game wont come out when i push the eject button?
I can fix that for you send me your phone number and I will go into detail on how.
Posted on Jan 01, 2009
  • 7 Answers
SOURCE: PS3 Jammed Disc Drive: Cant put it in, when its in, cant get it o
I can fix this for you!
just go to this link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300318746769
when you get your ps3 back this wont happen!
Posted on May 30, 2009
SOURCE: disc stuck in the drive of my ps3,,,i've tried
no. just turn on the game n pick up the system.tilt it completely over 2 where the part where u insert thte disc is facing the ground.then,hold down the eject button.simple. no number.no repairing.
Posted on Aug 26, 2009
Disc Stuck In 60G Console
  • Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Hi I have a ps3 slim and it just recently stopped ejecting my disks.when I press the eject button the ps3 makes a clicking sound but nothing comes out.but if I turn it off then back on it makes the noise...
    He is full of **** trying to scam you. It sounds like your disc drive is out of alignment with the top part of the disc drive so the clicking your hearing is the bottom of your disc drive trying to eject and the top is holding its on as the top has sliding parts that meet perfectly with the bottom part of the disc drive so it sucks the game in and out. You need to open it yourself with a philips head screwdriver you dont have to worry about the motherboard or any other part just take the drive out undo the ribbons connect the drive to the motherboard then it should pop right out. Been awhile since I took a slim apart they dont break as often (yet). From here you should have a metal caseing over the disc drive maybe not with the slim. You pop the metal caseing off the you have a plastic disc drive. Take the top part off maybe requires small phillips screw driver. Since you have a disc in it when you take the lid off hook the cables back to the ps3 motherboard and to the cd drive. Now press eject with the top lid off. Then put the top lid back on and insert a disc it should work. Then just put it back together. Theres a little motherboard on that cd drive do not short it out on anything. You can do this if you cant worst is youll have to buy a new cd drive from the repair shop you mentioned. Then they should charge to much labor to put it back together as you had it apart when you got there. But you should beable to do it if you need help taking it apart just google or youtube slim ps3 disc drive repair or how to take apart slim ps3. Hope this helps if not let me know.
    Dec 26, 2010 | Sony Playstation 3 (PS3) Console
    Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
    1. First shut down the system by flipping the power switch in the back off.
    2. Hold down the eject disc button.
    3. While still holding down the eject button, flip the power switch to turn back on your PS3.
    4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
    Nov 23, 2010 | Sony Playstation 3 (PS3) Console
    Disc wont eject and ps3 wont stay on
    Hi, best thing to do to eject disk is
    1.power of the console
    2. hold the eject button and the power button down at the same time
    3. then reach around to the back of the console and put the switich on
    4. hold for ten seconds and thhe disk should come out
    hope it helped!!!!!.
    Oct 09, 2010 | Sony Playstation 3 (PS3) Console
    Playstation will not eject discs
    try turning the ps3 off while holding the eject button then turn it back on while still holding the eject button. Its a misaligned tray.
    Aug 24, 2010 | Sony PlayStation 3 Slim Black Console
    Game is in Ps3, wont eject, says no game in the xmb screen
    if the disc is spinning with some clacking noise then its all right,use the manual eject button 3 to 4 times.Now the disc should be sited on the disc plate.If you think that this works but not through the software then update the firmware.On new slim PS3 disc stuck,it doesnt void your warranty.
    Thanks for using Fixya
    Jul 02, 2010 | Sony Playstation 3 (PS3) Console
    My game wont eject
    Okay, the same thing happened to me and I managed to get the disc out. First is the blue light on. If it isnt then you should hold the eject button and use another cd and push it into the disc drive and gently push your stuck disc around. When you hold the eject button your PS3 will make a loud clicking sound but dont worry. Just keep using the extra disc and push the stuck disc around and it should come out
    Mar 21, 2010 | Sony Playstation 3 (PS3) Console
    Feb 16, 2008 | Sony Playstation 3 (PS3) Console
    Ps3 jammed disc
    Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
    Jan 26, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    147 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
