Question about Video Cameras
Beeping c:31:23 When you have a tape in and try to record or play it will not work and a beeping sound and a trouble message of C:31:23 My ccd-trv-118 starts to record or playback and I get Beeping sound, ^_, fast flash. "C:31:22". I looked it up in the user manual, It says to removethen replace the battery and unpug the charger, remove and replace the tape. Re-assemble battery & tape, insert another tape--same thing happens. The recorder/playback is disabled in this cindition.
  • Anonymous Apr 11, 2009
    exact same problem!
I bought a new handycam that has no tape it recirds in Mini-DVD disks or a memory card. I just got fed up with tapes. Thanks.
Posted on Jan 24, 2009
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
Has error
It's a supply reel fault. I kid you not, the cure is to give it a REASONABLY FORCEFUL open-handed slap on the tape side. it may take a couple of tries but it works about 95% of the time.
Dec 03, 2007 | Sony Handycam CCD-TRV308 Camcorder
Error message; has something to do with insertion of tape. Looks like triangle over straight line. beeps and blinks, will not play. Working when loaned to a "friend", returned in this condition...
Will it record on a new tape? Will it play a different tape? Have had a similar problem with a different camera. Think it had to do with the record mode / play back. A bit like standard play and long play - are there setting like that you could change?
Jun 26, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
Not recording or playing back recorded tapes
first leave your camcorder with the cassete draw open in a warm room for 24 hrs.
then, use a brand new cassette & re try.
if you get the condensation message, it means the unit has detected moisture on the heads, the unit will not operate... hence your problems.
May 09, 2017 | Sony Handycam DCR-HC14E Mini DV Digital...
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
C 31:20 is my special message
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 11, 2008 | Sony Handycam CCD-TRV608 Camcorder
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Trouble recording to DV Tape
Hello, cleaning the head and the tape path with cleaning tape is a good idea. Try it! If the cleaning does not help the video head is damaged. If you need more info please advice.
Feb 16, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Video Cameras Logo
654 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
