Question about Music
Mp4 marshal me657 - Music
What would cause my Marshall Mode 4 amp to not change channels?
That can be caused by a faulty switch contact. I presume channels can be selected manually.
Aug 05, 2014 | Marshall Amplification Marshall AR-AM4,...
Marshall mg30fx
go here :-
http://www.amparchives.com/Amp%20Archives/Marshall/Schematics%20&%20Layouts/MG%20Schematics/Marshall%20MG30DFX.pdf
Apr 01, 2014 | Marshall Amplification Marshall MG30FX
I HAVE A MARSHALL 410H HALF STACK I WAS JUST PLAYING ON IT AND STARTED TO FADE OUT AND STOP MAKING ANY SOUND THAN I HEARD A LITTLE CLICK THAN THAT WAS IT CAN YOU HELP ME PLEASE.
The circuit is being overloaded and turning off automatically, file a claim with Marshall and they will fix it for free
http://www.marshallamps.com/support/support_overview.asp
Jun 20, 2011 | Marshall Amplification Marshall JVM410H...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I need the schematics for a Marshall MG30DFX guitar amplifier in order to repair it.
If you still want the schematics for the Marshall MG30DFX Steve I have them and can email them to you if you want
Dec 10, 2009 | Marshall Music
Marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Sep 09, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
126 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
