Question about Fujitsu 18C1 Air Conditioner
Replacemant of front return pan
Mice or rats have chewed the front drain pan on the left hand side above the drain plug. Can I replace this part without taking the unit off the wall?
    Problem Solver:
  • 11 Answers
What kind of unit
Posted on Jan 23, 2009
Tried everything n still wont crank. 89Suburban 1500 5.7 sat unused for 8yrs. Tried everything
Will need to completely drain and flush fuel system and tank for starters. May even need new fuel pump. Possible mice/rats/rodents have chewed through wiring. Need to get some oil on cylinder walls where it sat for those eight years.What does it do when trying to crank it now ?
Nov 15, 2015 | Cars & Trucks
Oil drain plug location
Hi Anonymous, I don't know what year your bike is but the oil pan is underneath the transmission. The engine oil drain plug is either on the front side left corner or the left side rear corner. The only drain plug that is actually on the bottom of the oil pan is for the transmission. Good luck
Feb 03, 2014 | Harley Davidson FLHRCI Road King Classic...
Where is the oil drain plug for 2002 road king
There are three oils. You do not say which one.
Dyna engine oil is on the left side bottom of the oil pan near where the jiffy stand rests when up and straight in from the side. The primary is under the middle of the primary case on the left side facing the ground and the transmission is under the right side of the oil sump case about mid way from front to back. All are 1/4 inch ALLEN socket heads inside 5/8 inch hex plugs. All use an o-ring and thread sealant.
Softail is the same except the engine oil drain is on the right side at the rear of the frame down tube near the swing arm attachment point and faces the ground.
Touring is the same except that the engine oil drain plug is on the left hand side front of the oil pan facing the front.
Sportster engine oil drain is on a rubber tube hanging down under the frame near where the jiffy stand rests when in its up position and the transmission and the primary use the same drain plug and are the same oil. The engine oil plug is a 5/16 inch plastic plug held in place with a mini worm screw clamp with a plain screwdriver or ¼ inch hex worm drive fitting.
Sep 28, 2012 | 2002 Harley Davidson FLHRCI Road King...
Where is the oil drain plug on a 2001 harley road king
Touring engine oil drain plug is on the left hand side front of the oil pan facing the front.
Dec 28, 2011 | 2001 Harley Davidson FLHRCI Road King...
Where's the oil drain plug on the 2000 fxdl?
The oil drain plug is at the front left hand side of oil pan, (under engine)
Oct 30, 2010 | 2000 Harley Davidson FXDL Dyna Low Rider
CANT FIND OIL DRAIN PLUG
the oil drain plug faces the front of the bike on the left front of the oil pan that is under the transmission. the transmission drain plug faces straight down on the right side of the same oil pan. the primary drain is a 40 torx plug just under the large derby (clutch) cover on the left side. Hope this helps, if you need more help just ask. Brian
Aug 07, 2010 | 2001 Harley Davidson FLHRCI Road King...
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
Wheres oi drain plug on 2002 electraglide
Left front corner of the oil pan.
Bottom right hand side is transmission.
Hope this is of some help.
Ed
Apr 28, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
How to change oil . Where is the drain plug ??
front left of the oil pan.
the other one Bottom of the pan right hand side is transmission oil.
Apr 12, 2009 | Harley Davidson FLHTCUI Electra Glide...
Fujitsu 18C1 Air Conditioner Logo
55 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
