Question about Sony DAV-C900 System
Unit displays "Program play of title 15 prohibited"
After unit displays the FBI warnings, it then gives text of "Program play of title 15 prohibited", locks up and finally goes back to the blank screen. Tried numerouw DVD's from various sources and problem is same with all.
Try making sure the repeat function is turned off on your DVD player.
Posted on Apr 21, 2009
I have a dvd set. The first disc in the set plays fine. When i try to play the second disc, it gets to the FBI warning and stops. Any suggestions?
FBI warning on disks are normal and is part of content on dvd, this has nothing to do with the fact that it stops playing (just coincidence) there might be a defect on the disc or scratches
May 12, 2011 | Sanyo DWM-390 DVD Player
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
Apr 22, 2011 | Panasonic Televison & Video
Program Play of Title 32 Prohibited
NO. it will most likely be either a limitation of the player or a faulty/incompatible disc.
A very quick test is to play the disc in another slot and see if the problem moves with the Disc.
Mar 17, 2010 | Televison & Video
G'day, I have owned and looked after my DXZ735 MP since 2004 and have recently had a new pickup fitted and a full service, along with some new firmware. The Title 'tags' have never worked properly and I...
I don't think there is anything wrong with how your doing the ID3-tag..
Have you tried pressing the [D] button while playing one of these disc's..
It sounds to me like it's reading the CD title as the ROOT (main) folder.
I found this in the manual:
Displaying CD titles
This unit can display title data for CD-text/MP3/ WMA disc and user titles input with this unit.
1. Press the [D] button to display the title.
2. Each time you press and hold the [D] button for 1 second or longer, the title display changes in the following order:
User title (disc) ? CD-text title (disc) ? Artist name ? CD-text title (track) ? User title (disc)... Folder ? File ? Album TAG ? Artist TAG ? Title TAG ? Folder...
For more info have a look at the online manual:
http://www.clarion.com/us/en/MungoBlobs/89/552/DXZ735MP(Manual).pdf
You will find the info on page 12 through to 13.
Regards
Mike
Sep 25, 2009 | Clarion DXZ545MP CD Player
Program play prohibited
This can happen if you have the "repeat" function turned on on your DVD player.
Nov 10, 2008 | Sony DAV-C450 System
GO VIDEO VR2940
hello davecad,
is this on all dvds you play even none store dvd's or just the store one,s only ?
this could be a region code or laser miss reading the disc.
riz.
Aug 07, 2008 | GoVideo VR2940 DVD Recorder/VCR
Pictures distorted play/record mode
Run the diagnostic software by unplugging the unit. Hold the Play while reinserting the power cord. Continue holding the Play until the diagnostic program is displays NUC XXXX where XXXX is a series of numbers. Once the diagnostics is finished it will pass or fail. To return to normal operation unplug the unit and reinsert the power cord after 15 seconds or so.
Mar 30, 2008 | Philips HDRW720 DVD Recorder
TITLE DISPLAY
Burn the CD using Window media Player. Also if your Head Unit will play MP3 files, Burn a MP3 format disc. It will display everything including the Author.
Nov 25, 2007 | Pioneer DEH-P3500 CD Player
Text Display Memory - Again
try replacing the internal battery
Oct 11, 2005 | Pioneer PD-F1007 301-Disc CD Changer
Text Display Memory
I am facing the same problem! By all means get it repaired. You can find the nearest Pioneer warranty station by calling 800-421-1404. You will need a copy of the purchase receipt when you bring it in for ervice. My story: I got it for a gif last Christmas, and after I had it for a month, it lost it's memory. (title index) So I called up Pioneer corp on the phone and this dude said make sure you don't have it hooked up to a switched AC. and I did, so I corrected that and he said use the remote to shut the unit off, oh by the way the remote sucks...!!!! but the memory is only lasting about three weeks or so. and it takes hours to put the cd's in memory. Anyway, i am on the way to ask for service...
Oct 10, 2005 | Pioneer PD-F1007 301-Disc CD Changer
Open Questions:
Sony DAV-C900 Home Theater System: problems with speakers and dvd picture quality Hello all, I hope someone can help me here... The speakers have been going off and on intermittently for a while now. I have cleaned the connections, but it does no good. Sony has these stupid color coded connectors and I do not know how to go about upgrading the wires. If that is even the problem. I have switched the wires around, and when I switch one that works to a non-working connector it will not work. When I put a non-working speaker wire into one of the working connectors, it will work--it almost seems to me that it is either a problem internally, or with that specific connector that sticks out of the rear of the unit. After fooling around with them for a while, I can usually get it to work, but then it will go out for no apparent reason. Another problem has to do with the picture. It has developed these squiggly lines while watching dvd's. Sometimes they go away after a while, but it is certainly annoying. I have attempted to clean the laser with one of those dvd cleaning disc's and even replaced the s-video cable, but neither has resolved this problem. It used to have an excellent picture, even though I wasn't using component cables. Due to my TV set-up, I need to use the S-video hook-up, but like I said it has always worked well until recently... We really do not watch that many movies, so I wouldn't think the laser is going bad--hell, the kids have many more hours on their xbox than this unit has...If I had the money, I would just go out buy a new system--not an HTIB this time, but this year has not been too lucrative, so I am stuck with this for the time. Any help will be greatly appreciated. Thanks Dana
Feb 22, 2007 | Sony DAV-C900 System
Sony DAV-C900 System Logo
110 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
