Question about Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
Whats size box should i use for ts - sw 301 pioneer sub
Noggin
  • 944 Answers
SOURCE: pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Posted on Mar 09, 2007
zoomiezz
  • 50 Answers
SOURCE: spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Posted on Feb 25, 2009
  • 65 Answers
SOURCE: i have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
Posted on Jun 07, 2009
hotratchet
  • 952 Answers
SOURCE: pioneer box
Thanks for using fixya!
I have had the same problem that you are having right now. I basically don't know how to start making my own sub box. Well, I chose the Bass-reflex type Box. This the best. Check this link out for a detailed overview of sub box making. http://www.hardwareanalysis.com/content/article/1789/build-your-own-10-inch-subwoofer/
Have a great day.
- HotRatchet
Posted on Jul 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Posted on May 04, 2010
What size of box in need Pioneer TS-W310D4
if its pioneer shop at walmart lol !!! try a speaker shop or read the manual it has that kind of info in it
Feb 25, 2013 | Pioneer Ts-w309d4 tsw309d4 1400w 12" Dual...
What amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Jan 30, 2012 | Pioneer TS-W307D4 Car Subwoofer
WHAT SIZE AND TYPE BOX DO I USE FOR ONE PIONEER TS-W304C SUBWOOFER
You have a lot of choices for this. First, unless you are tuning the sub to a specific frequency you have options. You didn't specify the size of sub so it's difficult to say specifically, but if it's a 12 inch sub, you need about 1.5 to 2 cubic feet. Of course the performance of the sub depends on the music you listen to. If you listen to rock, pop, classical, or country, I recommend a sealed box. A sealed box gives you better control over your sub. The air acts as a cusion and decreases the return time of the cone to rest position. This gives you tighter bass. If you listen to rap or hip hop, I recommend a ported enclosure. This type of enclosure allows for more cone excursion, thus allowing the sub to recreate lower frequencies. Hope this helps.
Aug 12, 2011 | Pioneer TS-W304C Car Subwoofer
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What size of box in need Pioneer TS-W307D2 12
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
If i put the TS-swx310 sub in a bigger box would it get help the sound.......i have a 12'' regular sized box and the speaker is going in a car now???
It is amazing the difference box construction can have on the overall sound of a system. Size is only one factor. Using a larger sealed box may make the sub hit lower, but not necessarily louder. Because the TS-swx310 is a shallow mount woofer, it is designed to run in small enclosure. Putting it in a much larger box could potentially cause damage to the woofer over time. If you want more bass my advice is to use a normal woofer in a box built to spec for it. Generally a ported box will provide more output, and sealed hits tighter. It all depends on the type of music you listen to.
Hope this helps
Please Vote & Rate
Mar 08, 2010 | Pioneer TS-SWX310 Car Subwoofer
Pioneer box
Have a great day.
- HotRatchet
Jul 26, 2009 | Pioneer TS-W307D4 Car Subwoofer
Building a box, need to know best dimensions for box and port
Hello dirt_digger6,
The specific sub you are asking about would seem to be the TS-302F which is the only 12" 800W Pioneer I have located.
Directly from Pioneer's support knowledgebase:
TS-W302F = Ported: 2.5 Cu.Ft. F3 = 39HzPort: 4  x 6.5 tuned @ 37 Hz with 12 % port noise.
An enclosure 16X18X21, constructed from 3/4" MDF will yield 2.69 Cu.Ft., allowing .19 Cu.Ft. displacement for the sub and port.
There's an excellent "box calculator" located here on the12v.com web site. You can measure the space you have to put the box and fiddle with the dimensions to get close to your ideal volume. There are also calculators on the12v.com which will allow you to calculate a port length based on port diameter (or width/height), enclosure volume, and desired tuning frequency.
Hope this helps.
May 07, 2009 | Car Audio & Video
Spl box 12inch pioneer subs pls
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Pioneer ts w33c
Mar 08, 2007 | Pioneer TS-W33C Car Subwoofer
Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer Logo
22 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
