Question about YDI Wireless Extended Range 802.11b Access Point (ap-ant)
YDI AP+ Hi, i have access point YDI AP+, my problem is i forget the password and i need reset to restore to default setting. i try with the reset button but not reset. thank's
  • 538 Answers
Press reset button and hold or 10 seconds.
Posted on Mar 20, 2009
Pin
1) reset your browser (internet explorer).
2) connect your access point (AP) to your pc directly using LAN port and CAT5 cable
3) type in default IP address of AP->192.168.0.50 (Or Current IP address of Ap) in browsers address bar.
4) username = Admin and blank password (i.e. password is no text)
5) Click on Advance Button then click on Wi-Fi Protected Setup button on left menu pan.
6) See the image below record your current pin, if you wish to change it just press generate new pin button.
7) Don't forget to say thanks :)
Apr 13, 2013 | D-Link DAP1360 IEEE 80211n (draft)...
Ydi ap plus won't reload factory defaults
Try This:
    • 1 Unplug all cables from the router except the power cable. Power on the router.
    • 2 Locate the reset button. This is typically a small hole marked "Reset."
    • 3 Insert the straightened end of a paper clip or the point of a ballpoint pen into the hole. Press and hold for about 10 seconds. Lights will blink, indicating that the unit is rebooting.
    • 4 Refer to your user's guide and follow instructions on setting up a new router.
Aug 01, 2012 | YDI Computers & Internet
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
I want to install another computer to my wireless access point but I have forgotten my password. Is there any way I can relocate this?
Which password you have forget? if you forget AP admin password then just reset it from rest button on AP. if you have forget security key then just go control panel with admin password and change key.
May 31, 2011 | Computers & Internet
How to reset orinoco ap 700
See the AP700 Hardware Overview below.... while the router is on.. press and hold the reset button (hole) for about 10 sec, using a paperclip.. the simplest way to restore your default setting..39f23e8.jpg
May 12, 2010 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
DWL-2700AP reset default settings
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
Jul 18, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Here are the steps to reset the access point from D-Link's website:
Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
The following reset procedure will completely restore the default settings on the access point including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the access point powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
You can find the complete manual for your wireless access point here:
http://support.dlink.com/products/view.asp?productid=DWL-2100AP
Mar 15, 2009 | D-Link Computers & Internet
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
Reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Apr 09, 2008 | Symbol Spectrum24 4131 Access Point...
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
YDI Wireless Extended Range 802.11b Access Point (ap-ant) Logo
159 people viewed this question
Top YDI Computers & Internet Experts
David Payne
David Payne
Are you a YDI Computer and Internet Expert? Answer questions, earn points and help others
