Question about DSC SCW-BATTERY - Replacement Battery for PowerSeries 9047
Why does my DSC 9047 still show a low device battery warning?
My DSC 9047 alarm panel showed a low device battery warning. So I decided to replace all of the batteries in the door sensors, motion detectors and the DSC SCW panel battery too. Finally the warning went away and I got a green light... but only for a few hours. Then the low device battery warning came back on. What could be wrong?
3 Suggested Answers
  • 54 Answers
SOURCE: i have a dsc power 832, and have replaced the
An "alarm Memory" indicates that a zone was activated the last time the system was armed. To view what zone caused the problem press the * key (star) + the 3 key. To reset the memory simply arm the system and disarm. Hope this helps.
Posted on Apr 23, 2010
Testimonial: "thanks for your help, however the system fails to arm, and tells me to secure before arming."
  • 194 Answers
SOURCE: the low battery signal showed and batteries were
When you replace the batteries for a keyless entry fob you have to sometimes reconfigure the fob with your vehicle. Please provide us with specific model of your vehicle and we can better provide you with a solution.
Good Luck,
NOLA Tech
Posted on Feb 08, 2011
I have ups working in normal operation but indicates alarm " low battery warning " and batteries charge 100% and i cann't rest this alarm
check the condition of the batteries if older that 3 years
the internals expand and split the outer cases
even though they may indicate fully charged , the capacity to run then pc may be severely limited making the alarm show
Dec 04, 2016 | Cars & Trucks
Low battery warning
Open the Control Panel and select Performance and Maintenance then Double click on the Power Options . Click on the Alarms tab and make sure the boxes are checked to activate alarms in both the "Low battery alarm" and "Critical battery alarm".
Mar 26, 2014 | Acer Aspire One D270-1679 Atom N2600 1
Alarm cannot be set
It will depend on your alarm system type and model. If it is not showing a zone number then most likely it is the main system back up batter which is located in the control panel on wireless models or in the metal can on hardwire models.
Nov 20, 2013 | Home Security
Dsc 9047 wireless alarm, had multiple sensor trouble, panel does not seem to recognize any wireless points, almost like wireless function has failed in keypad. Is this possible and is there a way to...
Chis power cycle system wait 60 seconds and try to see if points come back.Either your receiver is bad or your wireless points batteries are dead or somehow the wireless points got unlearned
Nov 02, 2013 | DSC 9047 Wireless Security Alarm Kit -...
I have a dsc power 832, and have replaced the battery, but i can not get it returned to the ready state as it shows " secure system before arming, and memory says -lid tamper", I have checked the plun
Hello Frank,
Great systems... Updatable, configurable...
even repairable... 832 is a "mature" system...
and the codes you get are not particularly helpful
if you don't have the ALARMS mapped.
There should be a map... (don't worry)
"-Lid" most likely is NOT the device you
are working on... Your ALARM condition
is FIRST on the warning list...
If you were given INSTALL notes with your system
you can use those... (instruction at bottom).
A simple area motion detector might also need a battery...
GLASS BREAK, SMOKE, HEAT, WATER... hard wired window devices...
(I'm guessing)... but FOR A FACT any device could
be mounted several ways... but control boxes
(at least in MY DAY had door & panel "TAMPERS")).
You obviously have a control panel
(you are getting system status "remarks)
It has been a long time since I have been around a DSC 832.
They are quite an excellent... and versatile security platform.
Lots of options and opportunities.
FIRST thing you will want to do is to inventory the system
to determine how many and what you are "monitoring..."
DSC PC5010 V2 0 Important Notice Page 4
Do look at this PDF ... (notice).
There are several manuals available
but before anyone can SERIOUSLY help you...
you need to walk the system and find all your devices.
Hope this helps
Jun 19, 2017 | DSC Power Supervision Relay For Smoke And...
Gemini home alarm system shows low battery
Check your charger unit it should be 13.8 volt if not its not charging also check for a short on you passives it could also give you a low battery warning
Nov 17, 2012 | Home Security
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
I have a dsc power 832, and have replaced the battery, but i can not get it returned to the ready state as it shows an alarm memory stating ''panel lid''. How do i reset this alarm message?
Apr 21, 2010 | DSC Power Supervision Relay For Smoke And...
My Humminbird Matrix 67 shows 11.3 volts on the
Hi!
Go into the menu (press menu twice) and look for the alarms tab. There is a setting you can change for a low battery warning, make sure it is set to off or as low as you can get it. Also it may be time for a software upgrade (available at a service center)
Best of luck!
Mike
Jul 08, 2009 | Humminbird MATRIX 97 GPS Receiver
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
DSC SCW-BATTERY - Replacement Battery for PowerSeries 9047 Logo
116 people viewed this question
Top DSC Home Security Experts
don1956
Level 1 Expert
L Pfaff
L Pfaff
Jerry Kramer
Jerry Kramer
Are you a DSC Home Security Expert? Answer questions, earn points and help others
