Question about Canon imageCLASS D320 Digital Copier
Copy is not clear
When I make a copy of something the result is a badly marred copy.  The copy is looks as if ink was smeared from top to bottom.  How can I clear this up?
  • 318 Answers
The first thing you must check is the small scanner glass,this is the narrow glass that the machine is using when you use the dockfeeder,clean that glass and make sure there is no back dots on the glass.Even a small dot can cause lines on your page.But this lines will only be sen if you using the docfeeder.
The second probem can be the drum cartridge that is faulty.With this problem all your copies and printed pages will have lines.
If your drum is ok,the next thing that goes wrong is the fixing assy.
Posted on Jan 23, 2009
My copier makes two dark lines from top to bottom of page. the lines shift with each copy.
you will need a part. either a drum, blade, heat roller. something is not cleaning or something is smearing the toner
Oct 22, 2009 | Office Equipment & Supplies
Canon Pixma MX 310 print smears.
You need to clean the bottom of the printhead, and use a Q-tip to clean the wipers on the clean station that is on the right side where the printhead parks. There are 2 or 3 squeegees there that wipe the bottom of the printhead and when there's too much ink it stays on the printhead causing the smears.
Jul 23, 2009 | Office Equipment & Supplies
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
All faxes sent have a dark black line going down the lenth of the
There is something on your scan glass that is blocking the light. If you open your ADF ( where you put the paper in to scan) like you are removing a jam there will be a long piece of glass. If you look at that glass there is probably dirt, ink smear, or whiteout smear on it. Clean that glass and try to copy a page. This should fix your problem.
Hope this helps.
Nov 21, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Nov 11, 2008 | HP 640 Inkjet Fax Machine
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Cannot get a good copy of a fax
Use ony GENUINE HP ink cartidges.
Look inside to make sure there are no scraps of paper that the paper is scraping against on the way out.
Mar 12, 2008 | HP 1040 Plain Paper Inkjet Fax
Installed new drum
dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Dec 03, 2007 | Sharp AL-1655CS Copier
Canon imageCLASS D320 Digital Copier Logo
90 people viewed this question
old marine
old marine
