Hi fixYa in my LG turbodrum 6.2 kg fuzzylogic control showing some time in UE in display after start then start from same time. what is the meaning of UE.
Some time running ok, after few day showing UE any solution.
  • 62 Answers
SOURCE: oily substance
most common is lint build up. a good hot wash with a good bleach...check your manual for manufacturer's recomendation. There's various products available..bleach is the most in-expensive and works well. make sure its set on high water level...pause machine for 10-20mins...let me know how you get on
Posted on Jan 03, 2008
  • 116 Answers
SOURCE: LG WM12220fd
I believe that UE is the fault of an unbalanced load which caused the drum to hit the switch or faulty load balance switch.
If the switch is stuck you can try to shake the inner drum kind of violently up and down (you won't be able to hurt it).
If the machine exibits the same error code with the drum empty then it is possible that the switch is damaged and will have to be replaced.
Posted on Aug 07, 2008
techbuster
  • 5081 Answers
SOURCE: What does PE mean on my LG washing machine
Check the pressure switch -the system that determines correct water level in the drum. If its giving an incorrect indication to the program timer machine will either overfill, refuse to fill or refuse to spin. Its an air operated diaphragm switch triggered by rising air pressure induced by the entry of water into an airtight vessel attached to the base of the drum. It tells the program timer that the water has reached the correct level, allowing it to proceed to the water heating stage in the cycle.
Power off, drag machine out onto the floor, remove back cover and top cover. The pressure switch is a round item about 3 inches across with several wires and a thin rubber pipe attached. It generally sits just under the top cover. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage.
Switch itself may be faulty but its more likely the pressure pipe or the vessel attached to the other end of the pipe is blocked. Some machines have the pressure vessel integrated as part of the filter unit, with a pressure chamber moulded into the top of the filter body. Remove the pressure vessel, put a small nut or screw in it, fill it with water and shake vigorously till any crud or residue is removed. Refit all parts, check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction.
Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Power off, drag machine out onto the floor, remove back cover or tip machine up at an angle. Locate sump hose, remove the tensioner clip by squeezing the tabs together with a large pair of pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
Posted on Mar 04, 2010
Daniel S
  • 4323 Answers
SOURCE: Hi why does my machine
Hi
UE error in Samsung washer indicates unbalanced load. You can try to leave it unplugged for few minutes to solve this issue or press and hold START/PAUSE button to reset this error. Please let me know the model# if you need more help.
Daniel
Posted on Nov 06, 2010
  • 472 Answers
SOURCE: Hi, we have a LG
working on lg for a while we have talked to tech suport and they don't want to admit they have a issue with these units.. first of all they say if on a pedastal they will give you problems but yet they sale the darn things... what we have found though is there is a device called a haul densor and it is very easy to replace you have to remove the backof unit panel and gain access to the back of tub... make sure it is connected well as it is on a rotor looking device called a stator assembly... if it is connected well and you have made sure it is level you have a bad haul sensor...thsi is what determines the speed of drum and slows down unit if getting out of balanced.. it is not that expensicve and pretty easy to fix.... hope this helps you out...
servicer 18 years
Posted on Jan 06, 2011
What does it mean when the washing machine suddenly stops and says "UE"?
This will help, for today and into the future, MERRY CHRISTMAS, Tim:
http://manuals.appliancesonline.com.au/wth550/wth550.pdf
Dec 25, 2016 | LG Washing Machines
LG TURBO DRUM DD WT-R854
my LG Turbodrum DD 8.5 KG WT-R852 have an Error Message (A). What can i do
Oct 25, 2012 | LG Washing Machines
My LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Feb 11, 2010 | LG Washing Machines
Error code UE
UE Refers that the Unit is Unbalanced. Take out the clothes out of the washer and then Run the washer. Does it Spin?
If yes, then it might be Unbalanced Load. Try to Load Small Clothes. If not, or if the Error is Appearing again and Again, Control Board or the Sensor is at Fault. You cannot Test the Control Board or the Sensor but usually Sensor is the Common Problem with Most of the LG Washers.
So, First Change the Sensor. If Problem Persists, Change the Control Board. On Most Models, Sensor would be Located near the Front of the Unit on the Side of the tub.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 26, 2009 | LG WM2496H Front Load
Letters UE on display
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 26, 2009 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
