Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
No sound, no picture and a red light blinks on front panel
My set is 13 months old. This morning I turned the set on and the following symptoms occurred. No sound, no picture and a red light blinks on front panel. Can anyone help? Thanks Dennis PS I already tried unplugging the set for 10 minutes
  • Dennis Morosco Jul 08, 2007
    Where can one get the code information? I beleive if it's a PC board I could change it myself.
    Thanks Dennis
  • Anonymous Mar 20, 2014
    Powers on fine good sound but no video, Can see images if i shine a flashlight on front panel? What should i try first and does anyone have a service manual i could buy or could you email me a copy @ dwayne_brooks@centurytel.net Thanks and May God Bless
    Scholar:
  • 150 Answers
If I remember right the set is blinking a code, dont remember which code, but what happened something on the power board failed and knocked out the 5vdc regulation? The power board will most likely need replacement, this should be done by a qualified technincian or someone who knows how to dissassemble/ repair set.
Posted on Jul 08, 2007
SOURCE:
No picture 11 light blinks
need the model number of the TV in order to be able to assist
Apr 03, 2012 | Televison & Video
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
Mar 24, 2009 | Televison & Video
Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Feb 20, 2009 | Sony BRAVIA KDL-40V3000 Television
Cannot turn it on using either the remote or set top switch. There is a click and red light blinks but no sound or picture. For some time if I hit the on button 5-6 times it would work but now it does not...
the initial symptom is usually caused by microprocessor as it is not initializing correctly. followed by 4 blink error which is i2c communication failure also specific to microprocessor would recommend replacing small signal board as microprocessor is located on that board
Jul 21, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
293 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
