Question about Canon PIXMA MX320 Color USB InkJet Printer
Error code 43
The MX320 show a error code 43
Dell latitude d830 screen not showing but external screen showing and on device manager NVIDIA QUADRO says windows stoped this because it reported a problem error code 43 and the drivers are up to date
Error code 43 means a driver either didn't load properly, is the wrong one or is missing.
Check video driver by running in safe mode. If it still won't work the laptop screen, replace the screen after checking it isn't the backlight by shining a bright light at the screen to see if anything is showing.
Jul 11, 2014 | Computers & Internet
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
MY DESK TOP COMPUTER, FX4710-UB003A STOPPED PLAYING MY GAMES AND A CODE POPED UP 43, I ALSO HAVE LINES ON MY MONITOR, I THINK IT IS MY HARD DRIVE.
Lines on the monitor is a signal that the monitor might be bad or the video card is going bad.
Try another monitor on the computer. If you don't have one borrow one from a neighbor, friend, relative or co-worker. If the other monitor works without showing the lines, then your original monitor is bad. If the other monitors shows lines just like your original monitor then the video card is going bad.
When does this code 43 pop up? Does it give you any error message with the code?
I looked it up and i think it has to do with a usb device.
Check the links below and see if they help you.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/code-43-error-on-windows-7/be1bdcca-7864-47c8-b9e0-cbc65488ba22
May 04, 2012 | Gateway FX4710-UB003A Core 2 Quad Q9300...
Device not detected
Whenever windows reports a code 43 error msg is because the device driver is corrupted or is reporting a failure, re-install the driver if error persist contact the manufacter of the device showing the error. Best regards Luis!
Feb 17, 2012 | Gigabyte GE-S800A-D1 ODIN GT 800W POWER...
Canon mx320 printer getting code error 5200
I have a canon Mx320 and I am getting the error 5200 how do I fix it ?
Aug 11, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
How do you fix error message 5100 on my canon mx320 printer. I just went and bought new ink cartridges for it and put them in and now it doesn't work and this error message shows on my laptop
error 5100 means that the printer cartridge carrier can not move freely.
see inside the printer and find the one causing the cartridge carrier to stop. It could be a piece of paper or a dried ink on top of the absorber pads.
Apr 18, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Canon PIXMA MX320 Color USB InkJet Printer Logo
23 people viewed this question
old marine
old marine
