Question about Reebok New York Giants Eli Manning Jersey
Brand new Reebok v6.80 treadmill, trouble on start up!
I just finished assembly of my new Reebok V 6.80 treadmill. On first start up, it sounds like bolts are being ground up in the motor, and the belt won't move. I turned it off immediately, as there is definitely something wrong with the motor. Any ideas?
  • roodev Apr 20, 2009
    I have this same treadmill never been used same thing happened,motor was busted because it's the wrong size belt they put on it,I'm 3 mouths into this.Reebok(Icon) can't seem to send the right belt,they keep sending belts too small, I have 4 of them,plus the one that came with it that was to small.They even sent their tech guy to come and repair it,with all these small belts,well needless to say, after I've told them a 100 times "THERE TOO SMALL" .Even the tech guy couldn't fix it,cause the wrong size belt was not there,but Reebok insisted it was the correct one...WRONG!!!!!! So it is getting sent back to them. Don't waste your money on this Treadmill,I'm very upset cause it's a beautiful treadmill with all the bells and whistles and the heavy duty motor and a 25 year warranty,but what good does it when it came broke and they can't even manage to send the correct parts!!!
I just had the same thing happen to me with the same treadmill. I called Reebok and they had me remove the motor hood. Sure enough, the bolts holding the motor had completely sheared off and the motor was lying loose in the bottom of the treadmill. They are sending a new motor and bolts and a technician to install them. They said it was probably dropped hard during shipping.
Posted on Feb 09, 2009
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
Apr 27, 2016 | Reebok Exercise & Fitness
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Knocking sound on Reebok z9 treadmill. Why does it happen? Did i ovover tighten the belt? Its brand new but knocking starts as it gets quicker. Also is suppose to go to 16kph but only goes to 10kpm. Any...
What is the frequency of the knock? Is it every second, few seconds, or very fast? This can tell if it has something to do with the track or the motor.
Feb 01, 2015 | Reebok Exercise & Fitness
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
My BRAND NEW Reebok 2.2 Motorised Treadmill Trips the electrics when swithced on. What is causing this? :(
See my block diagram for treadmill and see the fuse.
1) This ocurre for varios reason a) test the swicht power for short circuit.
2) the capacitor shor 3) the coil is short 4) the board is short.5) The power cord some wires is touche the carcase from treadmill, or some other wires inside is touching , test it
Now you must isolate the short with DVOM.
God bless you
May 10, 2012 | Reebok Exercise & Fitness
Where can i get an assembly manual for reebok treadmill
You can log onto iconservice.com, and type the model number into the manuals section. You get a pdf file of the manual.
Hope this helps, Matt
Dec 13, 2010 | Reebok Exercise & Fitness
Taking it apart a reedok performance runner
If the treadmill is a Reebok 8050 they have manual for it at iconservice.com. This compamy manufactures a wide variety of treadmills and the only way for sure to find the correct manual because they have the assembly instructions that canbe useful in the disassembly procedure.
Reebok
  • For questions about parts, service, user's manuals or non-working products for Reebok Home Fitness equipment, please call our Reebok Customer Service Department at 1-877-994-4999.
Jun 25, 2010 | Reebok 8050 ES Treadmill
Where do i put lubricant in my reebok treadmill t5.1
To lubricate your treadmill, start by lifting the edge of the walking belt and spread the lubricant between the belt and deck. Once you have finished on one side, do the same to the other side. When you finished both sides, start the treadmill at around 3 mph. Then walk on the treadmill to spread the lubricant on the deck for about a minute. Then your done.
Apr 19, 2010 | Exercise & Fitness
I have lost my key for the Reebok Treadmill
Any magnet will do. Otherwise order a new one from the manufacturer, other retailer or ebay.
Aug 10, 2009 | Reebok 8050 ES Treadmill
Reebok New York Giants Eli Manning Jersey Logo
2,455 people viewed this question
Top Reebok Sport & Outdoor - Others Experts
Tony
michael
michael
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
