Question about WYSE Link Max 700 Network Terminal
Max 700 - Diner Menu System
I have an old 14" Link - Max 700 terminal. This is at a restuarant. There is a Diner Menu system on this system. Obviously this is an old system but the other terminals work. I sent non-operating terminal to a shop in Indiana where they replaced the tube and made some adjustments. When I re-connected it, it looks the same as before! (I'll have to call them on Monday...) When I turn on the terminal I see the name of the program "Diner Menu" appear. After that all I get is a cursor in the upper left hand corner of the screen. The other terminals on the network show the menu on startup and then it goes to the actual menu input page. Any ideas? Thanks.
The people that fixed your unit, may have not replaced the E- prom, that may have been progromed for your system, I would call them to see if they still have the E- prom, if thay removed it at all. Not shure this is the problem but I have been working on terminals for 25 years and this is what I would check first.. hope this helps Bob Neilson, Interstate Terminals 304-728-4331
Posted on Jul 11, 2007
I am installing a SPST door switch in my closet and have two ceiling lights both getting power with a pull string. What is the sequence i should use when wiring these two lights to the switch ?
Assuming both lights are operated by the one pull switch and its working correctly as it is Just disconnect the black (hot) wire and the neutral (white) wire from the pull switch and connect them to the new switch black to dark terminal and neutral to silver terminal. You will obviously need to run a 14/2 cable from the door switch to the old switch location if you don't have one there.
Mar 15, 2015 | Electrical Supplies
Magellan roadmate 800 no turn by turn voice street names
http://www.magellangps.com/assets/manuals/Maestro_4000_Manual_EN.pdf
Nov 10, 2007 | GPS
How can I get a "BUrger King" restuarant menu?
Ask for one next time you visit them.
Feb 25, 2015 | Computers & Internet
I have an 2002 Nissan altima and DA display on the radio is working but no sound
Hi candy Love , I love that name ! What Altima ? S ,SE or SL
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
 through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
 to terminals + and - of front door speaker LH and RH
 to terminals + and - of rear door speaker LH and RH
 to terminals + and - of tweeter LH and RH.
BOSEĀ® SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
Ground is also supplied
 to speaker amp. terminal 17
 through body ground B117.
 to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
 through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
 to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Feb 01, 2015 | 2002 Nissan Altima
1-year old dustbuster black decker cwv1408 will not run unless I slap it on left side.
Your description would suggest either loose wire or a short in the switch. Take the unit apart and check to see that battery terminals are tightly connected.
Jan 02, 2015 | Vacuums
When turning shower valve to warm position the pipes start to hammer. the shower valve is a delta 13/14 series.
air in the system find the source of the noise usually a dip in a long run and insert a pipe clamp in two positions 1 ft apart then try again if this fails power flush the system
Sep 14, 2014 | Delta Home
1992 vmax stalls at idle when hot
Hi, Scott and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
stalling max VMaxForum net
98 vmax 700 Stall issue
http://www.vmaxoutlaw.com/tech/VMX12-Service-Manual.pdf
OEM parts for Yamaha
http://www.vmaxoutlaw.com/tech/owners_manual.pdf
Jun 23, 2012 | 2004 Yamaha V-Max
How to add freon to 1999 ford zx2
under the front wing is the low pressure port where you add the gas with the engine running and AC turned on full .max weight of gas for system is 700 grms
Mar 15, 2011 | Ford Escort Cars & Trucks
What is the towing capacity of a 1987 Chevy Silverado R 10 with a 350 engine,700 R4 trany, and two wheel drive?
The 700 R4 is old and not worth towing for it will have problems sooner than later in the overdrive if used. If used do not use the overdrive when towing. 4500 pound capacity is the max weight
Apr 24, 2010 | 1987 Chevrolet R10
I have mtnl garuida -fw modem, but i have no driver for this, so plz tell me how can i download driver, from where???????or what is link
elaine.teleport.com/%7ecurt/modems.html
www.drivershq.com/drivers
www.k56.org
www.itu.ch
www.chipset.com
TYPE IN THE FOLLOWING INFORMATION IN THE ADDRESS BARS:
HP COMPAQ EVO T20 NETWORK TERMINAL DOCUMENTS
HP COMPAQ EVO T20 NETWORK TERMINAL DRIVERS
HP THIN CLIENT T5135 NETWORK TERMINAL DRIVERS
HP THIN CLIENT T5135 NETWORK TERMINAL DOCUMENTS
HP THIN CONNECT RK271AA#ABA DOCUMENTS
HP THIN CONNECT RK271AA#ABA DRIVERS
HP E104
HP DK407AABA
HP 700/70 DRIVERS
HP 700/70 DOCUMENTS
HP 700/70 INFORMATION
I HOPE THIS CAN HELP YOU, BUT I MAY OF MADE MORE WORK THAN HELP
CANDYMANGANDY
Mar 07, 2009 | Computers & Internet
WYSE Link Max 700 Network Terminal Logo
98 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
