Question about Sony KLV-32BX310 32" Multisystem LCD TV KLV32BX310
Audio output is not functioning, how to get the audio output and no Headphone socket
Is there any change to be made for audio output
2 Suggested Answers
SOURCE: my sony dav-s-400 system keeps activating headphone port output.
Just had and fixed the same problem that hundreds of people are suffering with this system!!
Sony DAV s400 - same problem, won't play though speakers and display indicates that headphones are plugged in - when they are not. Fairly easy to fix and took me less than an hour from start to finish:
1) Remove top cover
2) Remove circuit board that has Audio In/Out phono scockets (to get access to Amplifier Circuit Board)
3) Remove Amplifier circuit board (has the speakers attached)
4) Turn it over and remove copper heat shield
5) Resolder joints where the big brown capacitor is and where the wires go to the front headphone socket...and any other dodgy joints that you find
6) Reassemble.
Posted on Apr 27, 2009
Have hearing problem, need to attach speakers to TV. We can't find a port for plug
Most TVs have a headphone socket. Some have an audio output socket and others have a scart socket but I haven't seen a TV that has a means of attaching speakers directly.
If there is an audio output it can be connected to a hi-fi or an amplifier and speakers and similarly a scart adaptor can be used for the same purpose.
Probably the best and easiest way is to use the headphone socket and plug in a pair of powered computer speakers
Mar 26, 2017 | Audio Players & Recorders
How can I listen to headphone on sharp aquos LC-26GA5U
Try to check is the is any Earphone sockets i your tv. If its there you can use headphone to listen to it. If its not there and is there is any audio out put sockets the you can buy a headphone amplifier and use it in between headphone and that audio output connector.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 31, 2016 | Sharp Televison & Video
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
No sound/audio while playing tv.
Hello
If there is no audio output from your tv, either your TVs speaker or its audio output IC has damaged. You just check it with an earphone/headphone, if there is an earphone or headphone socket in front panel of your TV. If there is sound from the headphone/earphone, and not from the speaker, means the speaker has damaged. You have to replace it with same type and number. Just check your set's audio out socket, if any provided, connet it to any external audio sourse, like amplifier or so, and check whether there is sound output from it. If not, your Tv/combos' sound processing IC inside has some trouble.
most common fault is related to sound output IC or speaker itself. If speaker is found OK, go to the sound output section. This section can be easly located as speaker wire goes to that section, and follow it. Before replacing the IC, check its leads for any loose or bad soldering. i advice you to resolder all the terminals of that IC, by applying a little more solder, without making any solder bridge loose contacts between them. If this does not helps, replace the IC with an identical type and number. OK.
Dec 24, 2010 | Panasonic PVQ-M2509 Combo
I just cooect headphone to VizioP50 HDTV & can't hear anything. is there some step I must do on the remote? Can't seems to find anything about this on the manuel.
You have to check if the headphone is functional and try inserting it 4 times to clear the headphone socket from any obstruction. When the headphone is inserted to the socket there must be no audio output in the speaker of the tv set.
Nov 04, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Can this unit be connected to my computer so I can make cd's?
It can if your computer has a 3.5mm jack audio imput.
What you need to have on your unit is and audio out socket. But if it doesn't have one you can use the headphone output. Then all you need is a lead. If you have the output sockets you just need a 3.5 jack to two RCA phono plugs one. If not you will need a 3.5 to 3.5 lead.
If using the headphone output, keep the volume low, use the computer recording device to adjust the signal level. NEVER turn the volume up high. Again if you are using the headphone output set tone controls to neutral, otherwise you will have either too much bass or treble on your recordings.
You can use the computer speakers to monitor the sound. Or you can get a headphone adapter plug that will allow to jacks to go into the headphone output of your unit, so you can connect a pair of headphones, but as I said don't mess with the volume control.
Feb 05, 2010 | Aiwa Z-R555 Shelf System
No sound in Gateway mx6030 MA2 Laptop
Make sure the audio cable is plugged into the MB properly.
Apr 15, 2009 | Gateway MX6030 Notebook
My sony dav-s-400 system keeps activating headphone port output.
1) Remove top cover
6) Reassemble.
Feb 03, 2009 | Sony DAV-S400 System
Sony KLV-32BX310 32" Multisystem LCD TV KLV32BX310 Logo
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
