Question about ION Audio iTTUSB Turntable
Sme problem but more
The morot spindel turns turns while there is power to it. I don't have a clue how to turn that off. There is no on or off switch only a stop switch which when pressed does no release the platter to reset to turn with out shutting down the the whole system and disassembling to reset manualy. The instructions manual I have doesn't give much trouble shooting information on the operation of reguler play, just on software trouble shooting in 5 different languages. I may have gotton a bad unit and am have troubles,
  • 42 Answers
I do not quite understand your description. However, the motor switch is underneath the deck and is very sensitive to adjust if you have to.
Try starting from scratch with no record on the turntable, the protector over the stylus. and the arm lifted with the cue button. The motor should not be running.
Gently move the arm towards the platter. The motor should start up.
Continue gently moving the arm across the platter slowly until you hear a slight clicking noise.
The arm should try to lift (it's already up) and return to the rest - it will stay up, of course.
After one more rotation of the platter the motor then switches off, or is supposed to at least, by a cam under the platter. You should hear the click as it does so.
It is all a matter of adjustment, and any knocks or bangs the deck may have had may have changed the set-up.
The STOP button you mention is so that you can start the arm lift- and -return cycle at any point on the record. It is not a switch.
Posted on Jan 25, 2009
I gete no spark at pluugs, no power at coil. on 4 leads i have battery on 1 leat ad coil. is coil bad???
that will be the fuel pump you hear probably . quite possably the ecm has failed
Mar 17, 2015 | 1991 Pontiac Sunbird
Off peak not working
Hi, Andrew,
This is not a radio/CB related post, so I can't help
Peter
Mar 03, 2013 | Radio Communications
I have a 2000 Kia sportage and my head lights and tail lights wont turn off plus my blinkers stopped working at the same time I haf to take the fuse out to kill the lights please help I don't have a...
On your model the headlight switch and turn signal switch are made together.
So I would say you probably need to replace the combo switch in the column which may require dismantling the steering column.
Feb 27, 2013 | Cars & Trucks
I changed the battery on a 2002 trail blazer then the a/c wont work
When the battery was disconnected, the HVAC system lost its calibration or one of the door actuators is stuck. With truck on, set all HVAC controls and switches to their OFF or CCW positions. Disconnect the battery, wait about 3 minutes, then reconnect. Turn ignition to ON position, doesn't need to be started, and don't touch any of the HVAC controls for about 3 minutes. This should reset the calibration. If this does not work, a mechanic will need to diagnose the problem.
Jun 21, 2012 | 2004 Chevrolet TrailBlazer
Trouble adjusting the water temperature for the Grohmix. I cannot get much coldwater.
hi
does the water flow decrease when you lower the temperture?
is there a pump on it?
remove the thermostat housing,their should be a grub screw on the side.
pull the housing off the spindel.
turn the spindel anti clock wise.the more you turn the lower the temperature.
refit housing
turn shower on and test
more info is required if this does not solve the issue
Dec 18, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
I can't find the blade lock used to remove my old blade. My model # is sears 315.108230
There should be a small black button on the right side of hand grip. You can also use a small block of wood between the blade teeth and the shoe to hold the blade in place while you loosen the blade nut.
Oct 31, 2010 | Sears Saws
Mountfield SP534 Lawnmower - Blade Spindel Bent?
That spindle shaft looks bent to me. Yes sir you've already proved that it is. Now your job is to take it apart and pound it straight (ha) or replace it (better).
Jun 27, 2009 | THQ The Lawnmower Man
ION Audio iTTUSB Turntable Logo
164 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
