Question about Crosley 0187SST Turntable
Suitcase Turntable stopped turning
I just bought a suitcase turntable Crosley and after playing it yesterday, today the table won't spin. Power source is connected, the unit is on, but all of a sudden it doesn't work anymore. Help!
  • 3 more comments
  • roddcook Aug 25, 2008
    I just bought a Crosley CR73. When I picked it up the guy was playing a Sinatra record on it. Next day I put on a record and the turntable would not turn. Any suggestions?
    Thanks
    Rod Cook
  • lslmiller Mar 21, 2009
    I have the same problem, but on the CR 249, I cannot access the drive band; it is incased.
  • Anonymous Mar 24, 2014
    It worked fine the other day. Today, I plug it in and get nothing at all. Switched plugs to be sure, but still no power to the turntable at all.
  • Anonymous Mar 31, 2014
    I need to know if the Crosley Stack'O'Matic is made anymore, I even looked on Crosley's official site and could not find one.
    I need to know if the Crosley Stack'O'Matic is made anymore, I even looked on Crosley's official site and could not finf one.
    Genius:
  • 2,985 Answers
Check the drive band- it may have come off the pulley. But if it is a new purchase then perhaps it should go back to the vendor
Posted on Jul 07, 2007
  • 432 Answers
It you hear the motor spin and nothing is moving, the belt could be broken.
SOURCE:
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
My crosley portable turn table will start but half way into a record it stops spinning; please advise
There is a small motor under the turntable that either uses a belt to turn it or has a rubber tired roller that sets up against it and spins. You will probably be able to find a belt or rubber wheel at a TV repair shop. Some models had an adjustment on them and can be adjusted but more than likely you will need a new belt or rubber tire. The tires looj like a big square :O: Ring
Mar 12, 2014 | Crosley Audio Players & Recorders
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
I have the Philco suitcase Turntable CD player. Art No. 841.237. When I got it from my friend, she hadn't given me the ac adapter/power source. When I got it, I assumed she had given me the right one. I...
I don't know whether your philco is the same as my crosley, but I recently had an issue where the record player stopped turning and it bamboozled me to no end. After digging up the manual online, I found out that you had to lift up the tone arm and move it to the right (past the holding clip) until it clicked, and voila, the record player started spinning again.
I hope this helps!
Sep 20, 2010 | Philco (R) Classic Turntable CD Shelf...
Turntable will not turn
I should imagine the belt has either slipped off or broke. If you lift up the turntable matt you might see it.
Jun 25, 2010 | Crosley (CR47) Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
spin the motor between your fingers, sometimes they develope a 'dead spot' if it comes to life let it run for a few hours, this may fix it forever.
Jan 22, 2009 | Philco (R) Suitcase CD Shelf System
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
Crosley 0187SST Turntable Logo
978 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
Gene Pitts
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
