Question about Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
About 6" of water in drum
wont do anything but flash FL
  • Anonymous Jan 30, 2009
    I have the same problem with the water and the fl code.
    John
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Posted on Sep 18, 2010
    Scholar:
  • 49 Answers
FL - Flood Condition - excess water in the tub. Could be a sign of a pump problem - impeller clogged, jammed, or maybe the motor shaft has stripped out the impeller hole and the whole thing needs to be replaced. The improved design has a single part for the motor and impeller assembly.
Manually draining the tub with a wet/dry vac (unplug the washer!) through the drain tube may be possible, or a combination of sucking out water from a tilted washer plus through the drain tube (get some help - water is heavy and you dont' want to tilt the unit while you also try to vacuum it out).
You can google the model # of the unit and find a Whirlpool Calypso service manual which is close (but not exact). I still haven't been able to get Sears to sell me a service manual for my exact Kenmore unit but the Whirlpool book is pretty good for some things, like the pump motor replacement. Part # 8178010 for the GVW9959K-0 Whirlpool Calypso.
Posted on Jun 13, 2009
4 Suggested Answers
SOURCE: Sears Kenmore Calypso Washer
Usually "FL" means one of two problems, both with the drain system. The good news is that both are relatively easy to fix yourself. "LD" can also be fixed by doing the following as well.
First, get the washer somewhere outside, in a garage or basement where you can afford to have large amounts of water spill out onto the ground. It may be easier to dismantle the inside of the basin and get as much of the water shop-vac'd out before you move it. Once it's outside, open up the back panel, and on the bottom left you will see a large black hose with clips on either end. Take the clip that attaches the hose to the bottom of the tub off and all the left over water will spill out. Turn it on it's face now, take the bottom panel off, and remove each of the clips on the hoses (drain hose to) and make sure nothing is blocking any of the lines. If it is, then remove it and this MIGHT fix your problem.
The other option (if the previous doesn't work) is to replace your pump motor, because odds are it has gone bad. The Calypso washers are notorious for having drain issues, and there was even a class action lawsuit a few years back that would have likely allowed you to get the washer fixed for free. If you do need to get a new drain pump motor, they go for anywhere between $80-100 and are a breeze to switch out. Hope this helps.
Posted on Mar 11, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Calypso error code reads FL...
Press STOP/CANCEL to clear the display. http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Should you continue to have appliance issues or need parts or service advice, please don’t hesitate to contact us. We are at your service from 7 AM until 9 PM CST Mon – Sat!
Thanks, Ella :>)
Posted on Nov 08, 2009
  • 530 Answers
SOURCE: whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
Posted on May 12, 2010
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
Flood Condition:
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
Just replaced the motor and pump, 3 weeks ago. Now I am getting an ld and then an FL?? Calypso Kenmore washer Elite
Flood Condition:
Mar 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore calypso wont rinse and displays the fl code.
Flood Condition:
Feb 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore elite with Calypso motion top load washer is reading FL and is asking for the overfill switch to be reset. water is leaking from underneath. what do i do besides turn the water off to the...
Flood Condition:
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
286 people viewed this question
Dan Webster
Dan Webster
Sal De
