Question about GPX ML648B MP3 Player
Will not connect to my computer, shows zzz on screen
Will not talk to my computer
  • alchemicsoul Jan 25, 2009
    it shows the sleeping mp3 player and computer on the mp3 screen which means it's not communicating properly with the computer. I'm pretty sure it's a software problem on the mp3 player it would be much appreciated if someone could patch this...
  • 8,596 Answers
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
Posted on Feb 15, 2009
I need assembly instructions for Your Zone Zzz twin over full bunk bed. Ours is missing manual.
fixya site doesn't have a zone zzz bed
contact the manufacturer
Jan 23, 2017 | Furniture
What is the IP address for 2WIRE378
If your 2Wire is functioning as the DHCP server, and has assigned your computer an IP address (and the LAN network light has gone green on the 2Wire) then you should be able to find the 2Wires address by looking at the Default Gateway address given to your computer.
On Windows XP, you can see this quickly from a Cmd window by typing in IPCONFIG /all and look for the listing under Default Gateway.
Try putting that IP address into your browser to access the 2Wire.
If your 2Wire is not doing DHCP (IE: It may be in bridge mode) and your computer cant figure out the 2Wires IP address (or the LAN Network light is not green) you will need to download and install a packet capture utility such as Ethereal (www.ethereal.com) and look for network traffic from the 2Wire.
Download and install Wireshark and then hook the 2Wire up via an ethernet cable directly to your computer.
Start the packet capture on ethereal and let it run for a minute or 2.
Stop the capture and look for ARP messages in the form of:
ARP Who has zzz.zzz.zzz.zzz? Tell xxx.xxx.xxx.xxx
The xxx.xxx.xxx.xxx should be the IP address of the 2Wire.
Say for example you see:
ARP Who has 192.168.2.111? Tell 192.168.2.254
This is the 2Wire at 192.168.2.254 looking to communicate with another machine (that likely does not exist, but thats ok.)
Write that IP address down so you can try it in the browser in a moment.
Now you need to statically assign your computer to be in the same subnet as the 2Wire.
That is you need to set your machines IP address to be like 192.168.2.5 (the .5 is just an arbitrary IP address) and a subnet mask of 255.255.255.0
That should allow the computer to talk to the 2Wire.
Enter 192.168.2.254 into the browser address bar and see if the user interface comes up.
If it does not, in some circumstances you may need to try a netmask of 255.255.0.0 on your computer and then try 192.168.2.254 in the browser again.
Once you have the user interface up and running you can reconfigure your 2Wire to what you need, either by adjusting things or doing a factory reset and starting over.
http://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
Mar 01, 2014 | 2wire Computers & Internet
SOLVE PROBLAM
Hello there:
please try these links and see if they will help you.
hopefully you have the genuine product
  1. Webroot Spysweeper...post Of "zzz" - The Elder Geek on Windows Webroot Spysweeper...post Of "zzz", Help with lost key code. Options. newbie geek ... site every day before I do anything else to see what is going on security wise. ...www.theeldergeek.com/forum/index.php?showtopic=6394 - 55k - Cached
  2. Webroot Spy Sweeper - Reviews and free Webroot Spy Sweeper downloads at ... Security Software. Spyware Removers. Webroot Spy Sweeper Webroot Spy Sweeper reviews ... to function and didn't acknowledge my current key code or subscription. ...
Sep 15, 2009 | Webroot Spy Sweeper (spysweeper) for PC
HOW DO I GET MY REMOTE OUT OF SLEEP MODE
Prestige car alarm car will start but red light come on when key in ignition and shut off.
May 28, 2009 | Vehicle Parts & Accessories
Not able to get the default gateway
Maybe the router is not set to give ip addresses. Try to activate the DHCP in your router and set the number of ip ad you wish the router would give.
May 02, 2009 | Belkin (F5D7230-4) Router (587009)
Delstar DS 31024 will not connect
if the mp3 shows zzz's it is waiting on you to copy something into it. :-)
Jan 03, 2008 | Delstar DS 31024 MP3 Player
E200r - Can't see new music.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 25, 2007 | SanDisk Sansa e200 MP3 Player
GPX ML648B  MP3 Player Logo
250 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
