Question about Kenmore 66469 / 66462 / 66464 Microwave Oven
Spacemaker 1800 Turntable
I have a GE Spacemaker 1800 Microwave (model #JVM1860BF 001) where when the turntable is operating I get a loud raspy noise and the turntable operates inconsistently. (When I switch the turntable off, I no longer get the noise.) The rest of the microwave's operation seems to be normal. The unit is mounted "into" my cabinets, where only the underside of the unit is easily accessible. Any idea of what might be my issue or how I can get into the turntable "workings"? (I see several screws under there, but don't really want to just start taking them all out if it's not going to get me where I need to go.) Thanks, Charlie
  • Charlie Zelinsky Jul 15, 2007
    Excellent !!! Very clear description, right down to part numbers, pricing and procedure to repair. Your solution gave me the confidence
    and ability to perform the repair myself - something I wouldn't have otherwise attempted.
    Thanks very much!
  • 4 Answers
I replaced mine, and it took 10 minutes.
If the turntable doesn't rotate, either the small ac motor has failed, or the coupling from the same motor has come loose. Here's how:
Unplug the main power to the oven. Remove the 5 or 6 screws underneath the oven to remove the access panel to see the small ac motor. There will be an electrical plug with two wires connected to the small motor---unplug it. Take out the 2 screws that hold the motor in place, and loosen the holding coupler (found underneath the glass turntable inside the oven) Inspect if anything seems to look broken. If everything is mechanically o.k., then the motor is bad. It's a fairly universal part number, a low voltage ac motor. Make sure that the voltage rating is the same when looking for a replacement. You could check on-line with a search-engine or Sears. I found mine in another oven that was being thrown away. It was FREE!
Good luck, hope this helps.
Posted on Apr 19, 2009
  • 5,911 Answers
If the noise goes away when you turn the turntable off, it sounds like you have a turntable drive motor that is going bad. They are fairly easy to replace and not terribly expensive. You can access the motor by leaving the oven in place and UNPLUGGED. Remove the bottom panel. You will need to remove the turntable coupler (the plastic piece that spins the glass carousel) and remove a few screws in order for the motor to come out through the bottom of the oven. There should also be a quick connect plug that plugs into the motor. The motor runs about $35 and the turntable coupler (if you wish to replace it as well), runs about $8. The part numbers are 769741 and 769278, respectively at repairclinic.com. I hope this helps you.
Posted on Jul 07, 2007
SOURCE:
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 Turntable malfunction?
You can find helpful exploded views and buy the replacement turntable motor at http://tinyurl.com/gv383 Need safety tips? See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM2070 Microwave Oven
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Nov 30, 2006 | Samsung MW1030WA Microwave Oven
Kenmore 66469 / 66462 / 66464 Microwave Oven Logo
256 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
