Question about Canon MP970 Photo All-In-One InkJet Printer
Error message i changed the black ink cartridge on my canon mp970 for the first time and when i tried to print a document i got an error message saying "inner door open, close inner door and press ok." can anyone help me? it seems like i have a defective sensor because the inner door is closed
  • 537 Answers
Check these links:,2500,6496,quote=1
Posted on Jan 23, 2009
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
Canon MP970 prints blank pages. How can I FIX that problem?
Some times when you get a new cart. a fine film can be blocking the
exit hole,check that this is clear by shaking the cart. up and down
over a large piece of paper ,if you do not get any ink out ,take a small
pin and gently insert it into the exit hole and move it around in a circle,
don't go to deep,then try shaking it again..? Another idea is to replace
all the carts.(colour ones also) as some printers wont work unless you
do this, after changing carts. disconect your printer from mains supply
and leave for about 15 minuets to reset..Hope this works for you
good luck. T.C.
Mar 31, 2013 | Canon PIXMA MP970 InkJet Printer
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
Unable to use canon mp970 with error 2.114.0
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP970 5100 error
I had this same problem. I took a flash light, moved the ink carriage and was able to feel around and find a small wad of paper. After removing it, I noticed a large amount of ink build-up running along UNDER the ink carriage. I took a damp Q-tip and got off as much as I could. To my surprise, it worked.
Jun 12, 2009 | Canon MP970 Photo All-In-One InkJet...
Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100 Yes see lots of this errors
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Error 9
The error codeE9 means
the connected digital camera / video camera does not support Camera
Direct Printing.......
Oct 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Canon MP970 Photo All-In-One InkJet Printer Logo
241 people viewed this question
old marine
old marine
