Question about Acer 6-cell Battery For Aspire 4739z, 4741g, 4743, 4743g, 4743z, 4743zg, 4750z, 4750zg
Grub problem for acer
Grub Problem Soluation
  • 47 Answers
SOURCE: partioned hard drive
Check this link:
http://articles.techrepublic.com.com/5100-10877_11-6031733.html
Should solve your problem.
Let me know what happens.
Posted on Apr 14, 2008
  • 7993 Answers
SOURCE: Acer M5641: computer crashed, mbr is corrupted, 'CD/DVD Drivers..
What I am going to say pertains to Windows XP (I cannot vouch it will work for Vista, because I do not have Vista).
Boot from the installation CD, Choose Repair installation. You will have access to the recovery console. Log in the Windows installation that is detected. You will be asked for the adminstrator password. Once logged in Type Help. In the list of commands available there is one called FIXMBR. Check its syntax by typing Help fixmbr, or even fixmbr ?
Type the correct command at the prompt and hit enter/return. It should fix it. After that Press CTRL ALT DEL to reboot.
If that does fix the mbr use another computer and query the microsoft knowledge base for Recovery Console (or the equivalent for Vista) and following the instructions.
Hope it helps.
Posted on Aug 29, 2009
  • 6 Answers
SOURCE: I bought an Acer 5542 computer three months ago
its ur pc fault.
Posted on Mar 17, 2010
  • 8909 Answers
SOURCE: screen stuck at error: no such partition, grub
Sounds like you have serious hard drive errors and may need to initialize your drive to allow the BIOS to see it. When you have done that reinstall Ubuntu and all of your drivers from the Acer web site.
Posted on Dec 27, 2010
Testimonial: "how do I initialize my drive when it does not recognize any command?"
  • 60 Answers
SOURCE: please help!! i can't open my notebook!!! when i
if you need a quick solution see this ubantu forum discussion
http://ubuntuforums.org/showthread.php?t=1357690
or else do a bit of research https://help.ubuntu.com/community/Grub2
Posted on Aug 05, 2011
Corrupted os
Have you tried a System Restore/Recovery? Do you have a Recovery Partition? Take a look here: http://www.unixmen.com/fixing-a-few-common-grub-errors-broken-bootloader-and-error-1715/
Apr 29, 2013 | Intel Hasee Nb Q540x-n 13.3" Laptop...
Tip
When a Windows install kills your dual boot to Linux
Distro installers are pretty good at identifying an existing Windows installation and setting up dual booting, but should you have to reinstall a spyware-riddled Windows install you'll find that your machine boots straight into Windows and that your Linux installation is gone!
Don't panic: all Windows has done is overwrite the Grub bootloader with its own equivalent, removing your boot menu. All your data is still there - you just need to reload the bootloader configuration into the disk's master boot record (MBR). You'll need to boot from a Live CD to do this, this, then open a terminal and run
sudo grub-install /dev/sda
This assumes you have everything installed on the first (or only) hard drive. Grub-install will usually make a good job of detecting a Grub installation and set things back to rights. If it doesn't, you'll have to do it manually, which is a lot easier than it sounds. Run sudo grub to enter the Grub shell. then run
find /boot/grub/stage1
...to determine which partition holds the Grub files. If Windows is on the first partition Grub is likely to be on the second, in which case this command will return something like (hd0,1). Now set Grub up with
root (hd0,1)
setup (hd0)
quit
The first command identifies the boot partition, the second writes the bootloader to the MBR and then you leave the Grub shell. Grub is only concerned with the location of /boot, so if you have a separate /boot partition, omit the /boot part from the find command.
on Mar 26, 2010 | Computers & Internet
Computer wont boot, recovery disk doesn't work after reinstalling it says an error has occurred.
There are two ways, choose which is suitable for you: 1) If you deleted a Linux partition and want to get rid of GRUB: - Insert your Windows CD. - In your BIOS settings, select boot from CD/DVD. - After the welcoming screen, type R (to enter the Recovery mode). - At the console (command-prompt/terminal) type: fixmbr - Everything should run fine after that. 2) If you installed Linux and have a problem with GRUB: - Insert your Linux distro CD. - In your BIOS settings, select boot from CD/DVD. - Enter the Live desktop and open a terminal. - Type: sudo grub -Type: find /boot/grub/stage1 (You might receive more than one location. Select the one you want to install GRUB onto) - Type: root (hd?,?) (Where "?" is the location you want to install GRUB) - Type: setup (hd0) (This is to install GRUB onto mbr) - Type: quit (To exit grub) - Reboot and everything should be fine.
Aug 20, 2010 | Computers & Internet
What is grub error 17? how to fix it?
Its GRand Unified Bootloader used in Linux OS.
Normally you get this error when GRUB is not able recognise the partition from which you are trying to boot the system. Make sure the boot partition on your system is recognisable by GRUB (such as EXT3).
You can try to restore the GRUB using the LIVE CD
  1. Boot From Live CD
  2. Open Terminal Window
  3. type >sudo grub
  4. then type : find /boot/grub/stage1
  5. you'll get something like: (hd0, 1)
  6. then type : >root (hd0, 1)
  7. type: > setup (hd0)
  8. >quit
  9. >exit
Remove the Live CD and reboot the system.
Please let me know if you need any further assistance.
Thank you for choosing Fixya
Oct 30, 2009 | Compaq Presario M2000 Notebook
GRUB PROBLEM on clone pc with Red hat linux 6.0
Boot up from Installation CD/DVD and type 'linux rescue' at boot: prompt, This will drop you at 'shell' prompt.
execute this
chroot /mnt/sysimage
cd /boot/grub
less grub.conf
less device.map
post the contents of device.map and grub.conf files ( first title, root and kernel lines of grub.conf ).
Apr 03, 2009 | Red Hat Enterprise ES 4 for Linux
Pc linux OS reboot loop
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,0)
(hd0,4)
(hd0,5)
(hd0,9)
(hd0,11) <-- You'll only have one, use it
(hd1,0)
(hd1,2)
(hd1,4)
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
succeeded
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
Done.
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Dec 06, 2008 | fedora Linux Operating System
There is no grub menu just grub command
Try running the command grub-install or if that fails, try the help command
You could also boot off the Ubuntu CD and be able to reinstall grub
Regards,
Deboo
Sep 24, 2008 | Canonical Ltd. Ubuntu
Ubuntu error 22
While in Ubuntu do:
sudo fdisk -l to find the drive you want to boot to.
On the command line type:
"sudo grub", this will give you the grub shell >
If the disk you want to install the MBR is sda* for instance, then type (at the grub prompt):
"setup (hd0)"
then type "quit" at the prompt.
Aug 25, 2008 | Canonical Ltd. Ubuntu
Acer 6-cell Battery For Aspire 4739z, 4741g, 4743, 4743g, 4743z, 4743zg, 4750z, 4750zg Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
