Question about Rosewill RX355-U External Enclosure
RX355-u not recognized as drive - Rosewill RX355-U External Enclosure
  • Rosewill Master
  • 2,072 Answers
With the drive plugged in, right click on Computer, Manage, Disk Management. If you do not see the drive in here. There is a problem with the drive or the enclosure the drive is in. Put your hand on the drive and check if it is spinning (vibrating). You can try buying a new enclosure from your local electronics or online store. Open the enclosure and pull the drive out and put in the new enclosure. If it doesn't work the drive is probably bad and you will need to replace the whole thing.
Posted on Mar 02, 2013
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
Wont recognize hard drive
If you recently bought it from a store or online it might just be a bad hard drive which happens. If your bios wont recognize it then it might just be an error with the bios firmware which can be updated from the manufaturers site.
Jun 11, 2013 | Computers & Internet
Slimtype DVD a Ds8a1p Ata Device Driver NOT FOUND IN MY NOTE BOOK AND NOT HAVING DRIVER IN CD
Go into your BIOS and see if the drive is recognized in there. If its not, then you'll need to turn off the laptop. Take out the drive from the system and then put the drive back into the system. Now go back into the BIOS and see if its recognized in there. If it is still not recognized then the drive is bad and would need to be replaced.
If the drive is recognized then go into windows into the device manager and see if the drive is there. If its not recognized properly then that means you might either have spyware or a virus on the computer. You can also try replacing the drive as well to make sure its not a drive problem.
Apr 19, 2010 | HP Computers & Internet
Dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Feb 04, 2010 | Gateway 5200XL PC Desktop
My d610 does not recognize my cd drive
Is the USB-compatible drive recognized when connected to some other computer? If OK, then the drive is OK.
Is _ANY_ USB device (memory-stick, camera, mouse, keyboard, printer) recognized when connected to any of the USB ports on your computer?
If not, then the USB device-drivers for Windows have not been loaded.
Drastic: backup all your data files, bookmarks, and music, to an external hard-drive, and reinstall Windows from the Dell-provided "System Restore" set of CD-ROMs.
Nov 14, 2009 | Dell Latitude D610 Notebook
DiamondMax 21 80-GB ATA/100 Hard Drive didn't get recognized as 1st drive or 2,3. do i need any software.
Use a partition manager to see if the drive is recognized. If it is not recognized, you may not have the jumper setting correct. If it is a master drive, set the jumper for master drive. same for slave or cable select
May 05, 2009 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Compaq evo n800c not recognizing hard drive
Test new HDD in another laptop or else. Make sure it's not DOA.
Jan 01, 2009 | HP Compaq Evo n800c Notebook
Hard drive not being recognized
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Aug 24, 2008 | Western Digital 500GB My Book World...
Rosewill RX355-U External Enclosure Logo
53 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
