Question about HP Pavilion Computers & Internet
BIOHD-4/-3 Error Since the just before the turn of the year, my PC stopped booting. It would appear to start after all the standard bios messages, and then I'd get a black screen with a cursor and nothing more would happen. I ran the hardware diagnostics HP included with the bios and all the hardware would check out as ok, but I'd get a BIOHD-4 error code for the MBR. I created a Windows Repair disk (Not to be confused with a Windows Restore disk) on another computer. I tried unsuccessfully to repair the MBR using the repair disk tools, but wound up having to delete the entire volume and start over with a new volume and partition. I then ran the reinstall disks successfully and managed to get the system back up. This worked for a while, but then the problem came back. This time I replaced the HDD with a new one, but now I can't even boot with either of the two DVD drives on the system, and the hardware test now produces BIOHD-3 error. All my settings in the BIOS are configured for the CDs/DVDs to come first in the boot order. Any idea what the problem is and how I might solve it?
    New Friend:
  • 11 Answers
Your BIOS is bad, sorry to say... but if the BIOS is glitchy the PC will never run right...tray to talk with an HP Tech...
Posted on Feb 07, 2015
5 Suggested Answers
anonymoose
  • 33 Answers
SOURCE: no c: local drive - Disk Error
Run BIOS diagnostic utility in DOS, reboot when you see "press F? to enter startup. navigate to whatever you want to fix or run, save changes, reboot.
anonymoose
Posted on Oct 11, 2008
  • 4 Answers
SOURCE: My computer will not startup
you should try and format all partitions and start all over
Posted on May 24, 2009
LMITC
SOURCE: Blue Screen c000021a
boot system into safe mode. locate the icon for my computer. right click and go to properties. locate the computer name tab and select it. find the radio button for "change" and click it. rename the computer to something considerably shorter then what you have. the system cannot boot and complete the logon process if the computer name is longer than 200 "bytes"
Posted on May 27, 2009
jeevan.m
  • 392 Answers
SOURCE: I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Posted on Jul 04, 2009
BIOHD-4/-3 Error
Can you double check the cables that you have connecting to your drives and make sure that they are properly seated and there are no kinks/cracks or any other issues. Additionally, make sure to reload the default parameters from your BIOS (press F10 at load to get to the BIOS screen) and probably change the first boot device to your DVD drive.
Jan 13, 2013 | HP Pavilion Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Computer won't boot, reading BIOHD-2 error code.
There are 3 step to repair biohd 2 error
If you got biohd 2 error then there is a 94% chance that your computer has registry problems. To repair biohd 2 error you need to follow the steps below:
* Step 1 - Download a biohd 2 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair biohd 2 error.
Jan 02, 2011 | HP Computers & Internet
Error unitialized corrupt boot structure detected biohd-4 boot path, keep getting this after trying to install windows 7, cant boot disk anymore so cant install windows 7
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Jun 11, 2010 | HP Pavilion Slimline s3620f Desktop
Biohd-5 Error upon running diagnostic. How to
1. Restart the computer.
2. Keep tapping the F10 key when the HP logo appears. BIOS Setup Utility.
3. Select the Diagnostic tab.
4. Select the "hard drive self test" option and press enter to perform the test. Note: This test takes atleast 40 minutes. This will take you to
Pass - The hard drive is not damaged.
Fail - The hard drive is damaged and may need to be replaced.
Aug 04, 2009 | HP Computers & Internet
Biohd-5 error pc boots err1err3
2. Keep tapping the F10 key when the Compaq logo appears. BIOS Setup Utility.
Jul 03, 2009 | HP Computers & Internet
I have an HP Pavilion Elite m9150f desktop PC. I'm getting ''Boot Path error code BIOHD-5 Failed''.
Could be one of two things: either the BIOS has lost the settings for the hard drive, which is uncommon unless the PC is more than 5 years old or been electrically shocked, or the hard drive is going bad. hard drives usually only last about 3-5 years on average. Western Digital even less.
Jun 13, 2009 | HP Pavilion Elite M9150F Desktop PC
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
How to fix Hp slimline Error Code BIOHD-5
Mar 09, 2009 | Computers & Internet
Computers & Internet Logo
99 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
