Question about Whirlpool 6th Sense 40-Gallon 6-Year Tall Gas Water Heater Natural Ga
The whirlpool water heater does not light bright enough to lite the pilot lite for the burner
    Sergeant:
    Champion:
  • 282 Answers
Check the gas control valve and also the thermocouple. Be very careful of a back flash it will burn your hands, arms and face if they are to close.
Good luck,
Marty
Good luck,
Marty
Posted on May 13, 2014
  • 2692 Answers
SOURCE: Pilot light will not stay on once button is released
Replace the thermocouple.
Posted on Mar 25, 2009
  • 61 Answers
SOURCE: pilot light wont stay lit
This usually means that you need to replace the thermocouple
Posted on Jun 28, 2010
  • 3 Answers
SOURCE: I have the whirlpool water heater model
have to take front door cover off when you look in the view port look up and to the left
Posted on Nov 23, 2010
  • 1015 Answers
SOURCE: I have a 40 gal. Whirlpool Water Heater and the
If you can light the pilot and it will stay lit while you are holding the button down but goes out when you release it then you need to replace the thermocouple.First turn gas valvle to off then remove the thermocouple line from bottom of the gas valve. It is the copper colored line that goes into the burner compartment and mounts in front of the pilot light..If your water heater is a sealed combustion with the cover screwed in place it is easier to disconnect gas line and pilot line from the gas valve also. Then take cover off and slide burner assembly out. The thermocouples come in many lengths so get one at hardware store that is at least as long as the one that is on there. The thermocouple slides into place in holder and is held there by friction. Try to center it as far in holder as it will go and make sure it is centered in pilot light. Reassembly being careful not to cross thread fittings into gas valve. Relight and hopefully you have fixed your problem. Thank you.
Posted on Feb 03, 2011
  • 20 Answers
SOURCE: have a 40 gal lp
Sorry to see you're having problems! Can you contact me directly so I can help?
www.whirlpoolwaterheaters.com/help
Thanks ~ Chris
Posted on Mar 01, 2011
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot hard to lite when lites stays on about 15 minutes goes out this is on reliance gas hot water heater 101
The thermocouple has gone bad or in this case is going bad to the point that it is useless.
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to ignite natural gas or propane fuel to the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners. Neat huh?
Feb 04, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Installed new thermocoupler heater still will not stay lite
Make sure the pilot light is hitting the thermocoupler, even when burner kicks in. Sometimes a dirty pilot tube will cause a weak pilot and it wont continuely hit the thermocoupler. I use air to clean mine. Hope this helps.
May 26, 2010 | RTO Atwood Water Heater - 6 Gal LP
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
This is a new whirlpool hot water heater.Pilot lights, burner fires, water heats up to temp. burner and pilot both shut down. Unit has to be started manually each time
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Feb 22, 2009 | General Electric GE SmartWater Household...
Cant get my waterheater lighter to reignite
Sounds like the gas valve has failed. The gas valve can be replaced. It will unscrew out of the tank. Shut the water supply to the tank off and get the new gas ready to screw in. Take out the old and screw in the new, you will onlt lose about a cup or two of water if you are quick enough. Otherwise drain the tank down if you must. If you are going to replace the gas valve I would also replace the thermocoupler.
Dec 18, 2008 | Water Heaters
Whirlpool 6th Sense 40-Gallon 6-Year Tall Gas Water Heater Natural Ga Logo
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
