Question about Electrical Supplies
Honda EU2000i EU2000 Generator Service Shop Repair Manual
  • 120 Answers
SOURCE: Honda eu2000 generator starts but no power to panel
You probably need to do a tune up. Change the spark plug, oil, air filter, and you may also need to add new fuel.
Posted on Jun 03, 2009
SOURCE: Need service manual for a Honda ES4500 generator
Where do you change the oil on a Honda ES 4500 Generator?
Posted on Feb 02, 2010
  • 5603 Answers
SOURCE: eu2000i lopes while idling. If i slide the choke
This is NOT uncommon when no load is on the units.
The "gain" of the govenor is designed for maintaining speed under load and will "hunt" a bit without a load on the unit.
Posted on Apr 04, 2010
  • 905 Answers
SOURCE: Coleman Powermate Maxa5000 ER Plus Generator
Unfortunately, a service manual is not going to be easy to find. You may be able to order from Powermate, but you may want to save your money and spend it on consumables.
I am guessing that you are looking for a service manual for the engine itself? Good Luck on that one as well, as Tecumseh has folded. Post the engine model# and other information found on the tag, somebody (perhaps myself) may have the manual you need and send it to you via email.
Parts for the engine itself are likely to be hard to find, consider an engine replacement. It likely will be cheaper.
Posted on Jun 12, 2010
GeneratorDan
  • 44 Answers
SOURCE: I need a repair manual
Try ebay thats were i go to find a hard to find manual. Hang onto that generator those es 6500 s are hard to come by . Hope this info helps
Posted on Nov 07, 2010
I have a deep eu2000i inverter, the problem is to remove the carburetor throttle, it takes some kind of setting as to start the engine low speed, and connect a tool fails ....
if your question is that my Honda generator wont idle up when I connect a load (tool) and it stalls then . first see if unit will run on constant setting (switch on front) if nothing or still barely runs or stalls , then your problem is carb or fuel filter (inside tank) one or both is most likely dirty and needs replaced/cleaned
Oct 15, 2016 | Honda EU2000i Companion Inverter Generator...
I need the wiring diagram on a Honda generator model eu2000i for the front cover on the inside any the wire diagram
Type maker, model, user manual in computer search engine. It will bring up sites to get user manual. In the manual, there is a wiring diagram
Dec 13, 2015 | Honda Electrical Supplies
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
Should i use regular gasoline in 2000 watt generator
It is ok to use 87 octane regular unleaded gasoline in a Honda EU2000 generator. I have been running it in mine for 4 years with no problems. Using the higher octane blends is just a waste of cash.
May 22, 2014 | Honda EU2000i1A1 - 2000 Watt Generator
Screeching sound-Honda eu2000i
Sounds like a bearing has failed or something has gotten inside the generator or engine area where it spins and is now rubbing against it. There is a bearing at the far end of the generator from the motor and it is most likely to be where the noise is coming from. Best to repair it before it seizes and wears out parts you don't want to have to try to find!
Oct 30, 2012 | Honda Eu2000i 2000w Generator
I have a 2 month old Honda Eu2000I generator that until today has performed flawlessly. The ac output suddenly stopped though the output light continued to glow green and the engine continued to run. The...
Try checking the output with another appliance, the shop vac may have over heated (for whatever reason). The generator, if it encounters one, has a fault light (if memory serves) that is illuminated if anything out of the ordinary is encountered.
Feb 13, 2011 | Honda Electrical Supplies
May 28, 2009 | Electrical Supplies
Honda EU2000i with a washing machine
Yes - it will be a fine machine to have and do well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore Washing Machines
Electrical Supplies Logo
240 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
