Question about JVC FS-D88 Shelf System
How do I fix the volume control on the JVC FSD88 Stereo Component System? I lost the remote and the volume control doesn't work
The volume control started breaking (it wouldn't increase or decrease volume without turning it significantly at first... but now it is stuck all the way at top volume, and won't turn down!)...
SOURCE:
  • 579 Answers
SOURCE: Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Posted on Jan 08, 2008
maklean
  • 1665 Answers
SOURCE: Need help with my stereo
See troubleshooting section at the its user manual below.
http://www.retrevo.com/s/JVC-HX-D77C-CD-Players-review+manual/id/314ci352/t/1-2/
Posted on Jan 17, 2008
simplemitch
  • 752 Answers
SOURCE: Remote control
You need to resurface the contacts. Here's how you do it:
First, disassemble the remote. Clean the black foil pads on the circuit board with rubbing alcohol. Now take a #2 pencil and a razor and shave the graphite from the "lead" onto a piece of paper (hold the blade perpendicular to the lead, this results in a finer powder). Now that you have a nice pile of powdered graphite, blot a Q-Tip into it to saturate the cotton with graphite. Rub the graphite onto the little black pads on the rubber button membrane, and be sure to apply more graphite to the Q-Tip every 2 to 3 buttons. Blow off any excess graphite. reassemble remote and test.
Posted on Aug 04, 2008
marked
  • 6487 Answers
SOURCE: NEED TO SET UP COMCAST
Try using code 00002
Hope that helps.........
Posted on Aug 18, 2008
  • 3 Answers
SOURCE: HELP STEREO CUTS OUT!
ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
Posted on Aug 19, 2008
JVC MX-C5 Compact Component System has a broken mini gear
If you can't get it to work, I would love to purchase the remote as I have lost mine.
Dec 04, 2013 | Harman Kardon JVC UXG50 Micro Stereo...
My JVC stereo doesn't play cd's anymore, still runs audio for tv, and radio. What is best, low price stereo option i can hook speakers up to and play cd's again?
The CD player might just need it's lens cleaning. Best way to do this is taking the top off and cleaning the lens with either Servisol Video 40 or CD lens cleaning fluid.
Mar 03, 2013 | JVC MXKB30 300W 3-Disc CD Shelf System...
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
The remote control doesn't work anymore on my AIWA NSX-SZ50 compact disc stereo system.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 14, 2011 | Audio Players & Recorders
How to program the TV remote to work with an APEX DVD player? I do not have the APEX DVD code.
As far as I can remember, the original JVC remote doesn't support a DVD player. It doesn't have the necessary buttons to control the player functions. You'll need to stick with the original Apex remote if you have it, or look for a universal remote that is compatible.
Jul 30, 2011 | JVC AV-32D502 32" TV
When i use the volume button on the remote a yellow icon comes up and i cant change the volume, help please
You may have the FIXED VOLUME LEVEL feature enabled in the AUDIO OPTIONS section of your TV's menu. You should be able to disable it from that menu as well if necessary.
This feature is often used when you are sending the audio signal out the rear audio output connectors of the TV to a stereo or home theatre system amplifier. That way you hear the TV audio through the stereo's large speakers instead of the small TV speakers. Then to raise the volume of the TV audio, you simply adjusting the volume of the stereo with the stereo remote instead of using the TV remote.
If the channel selector does not work either, then it's possible that you may have the CHILD LOCK feature engaged. See you owner's manual for instructions on how to disable the CHILD LOCK.
Good luck, I hope this was helpful.
Jul 04, 2011 | Televison & Video
How do I hook the cabels so I can control the valume with the TV remote?
What type receiver and which component do you want to control the volume? Give me model numbers and is it a separate component. Usually the remote should control the receiver volume. and anything connect to it. Is this a car stereo or a home system? If its a home system even if its new. It might be bad batteries or bad remote. Let me know more.
Dec 25, 2010 | Audio Players & Recorders
97 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
