My thermostat is a braeburn it runs my heater and ac in my house it just keeps beeping
I changed the batteries and then i turn the themostat off. it still won't stop beeping
  • 415 Answers
SOURCE: I have a Braeburn 5000 thermostat how do I change
Use the below link to obtain the manual for your thermostat. I found the "Set Current Time & Day" instructions on page 4 of this manual.
http://www.braeburnonline.com/products/item/24-5000.html
Hope you found this information to be very helpful to you. :-)
Posted on Mar 16, 2010
  • 59 Answers
SOURCE: wall heater will not turn on
PILOT MY BE BLOWING OUT. IF YOUR WALL HEATER IS NEAR FRONT DOOR IT MY BLOW OUT. ALSO IF YOU HAVE A WEAK THERMOPLE IN PILOT IT WIIL SHUT OFF PILOT. WE USE MILIVOLT VOLTAGE METER TO CHECK WHAT THERMOPILE VOLTAGE IS. IT SHOULD READ 250 MILIVOLTS .CHECK THE LIMIT SWITCH MOUNTED IN TOP FLUE INLET IT SHOULD BE CLOSED AT THE 2 SPADE TERMINALS. CHECK ALL SCREW TERMINALS THAT THEY ARE TIGHT. HOME DEPOT MIGHT HAVE THERMOPILE FOR WALL HEATER
Posted on Apr 21, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Williams wall
The thermocouple is weak and does not hold the gas vlave on.
To get it to work right you need to change the thermocouple.
That is the metal rod that the pilot flame is hitting.
heatman101
Posted on Apr 16, 2011
heatman101
  • 43501 Answers
SOURCE: our thermostat has "HOLD" on
Hi, Either push the program or resume program button... or on some you need to push the hold button again to take the hold off... Check the manual if all of this does not work... but the t-stat may be fried...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Jul 24, 2011
SOURCE: Replaced the thermostat on a fireplace heater from
Maybe need a Millivolt thermostat ?
Posted on Nov 10, 2011
We have braeburn 1020 and we live in arizona where it has been 116 degrees or higher. The thermostat changed itself to 90 and will not adjust. AC will not come on at all. It has new batteries.
Turn power off to air handler. Remove red, green and yellow wires from tstat and wire nut together. Turn power back on. This should bring on condenser and blower. Let run and be sure it's working. If all is working you will know the tstat is bad.
Jul 08, 2017 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
When my braeburn digital ac reads -ac on the display
36d2676f-8a79-4391-9b58-fe5611f97404.pngYou need to ask your question in full, it was not posted.
Aug 27, 2013 | Honeywell Programmable Thermostat Heater
I have a Braeburn 5000 thermostat how do I change the time?
Mar 15, 2010 | Honeywell Programmable Thermostat Heater
Need to know to replace themostat in 2004
Drain the radiator, follow the top radiator hose to the engine, it is connected to the thermostat housing. Loosen and remove the two bolts, lift the housing and remove thermostat, make sure the new thermostat goes back in the exact same way, tighten bolts, make sure pepcock is closed on radiator, refill radiator, start engine, run heater on full blast, add coolant as needed.
Dec 22, 2009 | Chevrolet TrailBlazer Cars & Trucks
How do i change thermostadt on jeep cherokee
  1. Follow your upper raidator hose untill you find the themostat housing which is the ending point for the hose.
  2. Remove the two bolts that hold the housing (you may have to loosen the belt to get to one of the bolts).
  3. Remove housing and replace themostat and gasket ( remove any excess gasket that may have been left over ).
THE DETAILED PROCEDURE IS GIVEN BELOW
  1. Open draincock on the radiator to drain the coolant from your Jeep Grand Cherokee. This draincock is located on the lower right side facing the rear of your Cherokee.
  2. Use a sealable container and reuse the coolant if it is relatively new and clean.
  3. Follow the upper radiator hose to the point where it meets the thermostat housing. The thermosat is located inside the housing.
  4. Use a clamp tool or vise-grip pliers to loosen the clamp holding the hose to the housing. Work the end of the radiator hose free of the thermostat housing.
  5. Remove two bolts holding on the thermostat housing cover. Pull off the cover.
  6. Take note of the position of the old thermostat. Remove and install the new thermostat in exactly the same position.
  7. Scrape off residue of the old thermostat gasket from the inside of the thermostat housing cover using a razor blade. Avoid getting any debris inside the thermostat housing.
  8. Install the new gasket. Reattach the thermostat housing cover and radiator hose. Start your Jeep and run the heater on high. Allow the engine to warm up. Check for leaks.
Nov 08, 2009 | 1996 Jeep Grand Cherokee
Honeywell CT200A thermostat battery will not recharge.
Yes the battery charge circuit is burned out, you might as well replace the thermostat, parts will not be made to fix it unless it is still under warranty.
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
1992 Jeep Wrangler heater not blowing hot air
How often has the coolant been changed? My only guess is that it hasn't and the hoses and the heater core are plugged up with goo and a flush is needed
Dec 05, 2008 | 1992 Jeep Wrangler
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
