Question about Refrigerators
Refrigerator not cold, freezer only cool
Hello, I have a GE model PDE18LBRARSS. The fridge is warm and the freezer cooler than usual. The other night the fridge wok me up as it was making a fairly loud noise, which eventually stopped. I've looked at the ouside back and there was some accumulation of dust which I removed. I adjusted the temperature controls, turning them off and back on. The door is properly closed. I can hear a small fan-like noise but the the full usual sound indicating that the fridge is working as usual. I also ensured that the electrical plug and outlet are ok as well as the breakers, and all seems fine from an electrical in-home point of view. Grateful for any advice. JB
  • J.B. Jan 13, 2013
    When i open the freezer's door and hold the door switch which turns off the light, there is no discernible difference in terms of hearing the fan running faster or slower. The freezer part I can see some amount of "steam" and the food is still cold, but the main fridge part is where the lack of cold of cold is most noticeable. Regardless of changes made to the temerature control, there is no change. There is no large amount of frost anywhere in the fridge even with the controls at the coldest.
    Problem Solver:
  • 16 Answers
There is a set of coils in the front down at the bottom behind a plastic cover. Sounds like they need to be cleaned with a steel brush.
Posted on Jan 13, 2013
  • J.B. Jan 13, 2013
    Thanks for the suggestion. I am unsure which part of the fridge being referred to. There is a plastic black strip outside the fridge right under the freezer door. That black plastic strip is easily removable but seems to be more for decorative purposes as behind it can be found the metal part of the fridge's body. The other location which you could be referring to is the platic strip which is white located in the fridege itself. It has those little vents-like openings. This is the one I suppose you are referring to. Unfortunately, this plastic part is incorporated into the structure and i don't see any reasonable way to remove it without risking damage to the appliance. Do you have any set of instructions referring to the removal of this plastic part inside the fridge (if that is indeed the one being referred to?). Thanks for the help.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
SOURCE: Honeywell compact refrigerator model #
It seem this problem is common to all 88031. One of my customer have 8 of this model in her motel rooms and all problems are the same as your's. My experience in refrigeration and electronic board tell to me this problem is from the fact of humidity comming from everyware(diff. of tempereture, electronic board near the floor, heating from the refrigerator, etc. I find a lot of trace of humidity on the board.
Anyway, like we said in Abitibi, your dog is dead and the only solution is to litter it in a safe place and by a new but this time with a compressor to make cooling, not a fuc.......electronic board.
Posted on Nov 20, 2009
GE concept 2 fridge/ freezer combo. Freezer suddenly stopped freezing anything . It's cool, not even as cold as the refrigerator part. Any ideas?!
Hello:
Check if there is any frost buildup on the back wall inside freezer. Maybe your defrost system failed and ice is blocking the air flow(no air flow you just got a cooler )
Jul 07, 2017 | GE Refrigerators
Temperature playing up going up not down
Refrigerator Not Cooling Enough - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
If the refrigerator is running, but not cooling at all or is not cold enough, several ... To view a short video on adjusting the temperature on set point models: Play ...
How To Fix A Refrigerator and Freezer That's Too Warm ...
www.partselect.com/Repair/Refrigerator/Refrigerator-Freezer-Too-Warm/
If your fridge and freezer is too warm, don't give up - we can help. ... The cold control is a temperature controlled switch that supplies power to the compressor ...
Nov 21, 2015 | Refrigerators
Side by side ge fridge model number gss22kgpabb. not cooling on either side freezer is cooler than fridge side but not cold enough to make ice. What do I do to troubleshoot. Also has a slight layer of...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | Refrigerators
Hi i have a GE profile with avac freezer working but fridge is warm what should i do anything will help thx
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Feb 16, 2011 | GE Refrigerators
I have a ge tfx24fg the fridge part is to warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 07, 2010 | GE PSC23SGRSS Side by Side Refrigerator
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 02, 2010 | GE GSH25JFT
I have a GE SxS that sounds like it is running all the time. The freezer appears to be fine, but the fridge is not cooling like usual. In fact, we have change the temp settings to make it cooler and even...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
