Question about Compaq Presario 700 470024-192 Notebook
Having to reset modem/router everytime I boot my laptop.
When I boot up my laptop it will nt reconize my belkin router unless I reset it and my comcast modem at the same time. After that It works fine.
  • seaj25 Jan 24, 2009
    thanks
  • Anonymous Jan 24, 2009
    hols
  • 43 Answers
Try uninstalling and reinstalling the drivers for the network adapter from the device manager.once you uninstall just reboot, search for the network and you should be able to connect no problem.hope this helps!
Posted on Jan 24, 2009
Can't set up Belkin 54g Router with MTNL broadband
Samay,
You should reset your router to clear all information from it. The best procedure to fully clear your device would be to press the reset button with power on for 30 seconds; while continuing to press the reset button, remove power from the unit; and while continuing to press the reset button restore power for 30 seconds.
You should now be able to access the menus after the unit boots up with the default user name/password for the unit. If you do not know them, just Google [your router name] default user name and password. You can now set up the router to meet your requirements. There is a lot of information that will help you on the Internet, but having a clean booted router is important to start with.
Mar 17, 2014 | Gateway Belkin 54g Wireless DSL/Cable...
Tip
Wireless Network Reset - Belkin
If you are unable to connect your laptop wireless to your <b>Belkin</b> wireless access point/router, the <b>easiest</b> and<b> fastest</b> way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.<br /><br /><br /><br /><b>Reset your router:</b><b><br /></b><br /> <ul> <li><b>Unplug</b> your <i>DSL/Cable</i> <b>modem</b> from power (not your access point/router) Leave this unplugged for now</li></ul><br /><br />Next <ul> <li>On the rear of your<b> Belkin router </b>you will find a small RESET button</li> <li>With the power still on the router,<b> Press</b> and<b> hold</b> (with a pin/pen tip) the <b>RESET</b> button for 10 seconds.</li> <li><b>Release</b> the RESET button a wait 15 seconds for the router to reboot</li></ul><br /><br />almost done.... <ul> <li><b>Unplug</b> your <b>Belkin</b> router from power</li> <li><b>Plug</b> your DSL/Cable <b>modem</b> back in to <b>power</b></li> <li><b>Wait </b>1 minute for the modem to boot up</li> <li>Be sure the ethernet (cat5) cable from your <i>modem</i> is securely plugged into the <b>WAN port</b> on the back of your Linksys <i>router.</i> This is usually labeled <i>WAN</i> or<i> Internet</i> above the jack</li> <li><b>Plug</b> your Belkin <b>router</b> back into power.</li></ul><br /><br />You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.<br /><br /><b><br /></b><i><b><br /></b></i><i><br /></i>Magoo
on Mar 13, 2011 | Computers & Internet
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Dec 21, 2012 | Comtrend CT-507 Router
My router does'nt read the modem, it never stop boothing!
Remove ALL cables, verify connections , connect cables, Unplug the Modem, remove battery, unplug the Belkin. Install battery in Modem and plug in, let it run a selftest, when finished, plug in Belkin allow it to selftest. Reboot computers.
Dec 12, 2012 | Belkin F5D8236-4 Router
Reset my belkin router now i can't connect to
if you truly reset your router then you may have to reconfigure it. If your belkin router is also your dsl modem or cable modem then you will have to call your ISP provider and get your user id and password to start with.
I have a feeling this device does double as your modem since you now cannot connect. Most routers will work as a router right out of the box. However if your modem is seperate then it may expect your router to have a different subnet for its IP address then the default. Try plugging your computer directly into the modem if that is the case. If it works then just reset the routers IP address to be on the same subnet.
Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
Dec 16, 2009 | Belkin (F5D6230-3) Wireless Router
I loose internet everytime the phone rings
Absolutely. Wireless LAN is on 2.4GHZ. You will want to get a phone at a different frequency.
Apr 05, 2009 | Belkin Computers & Internet
Belkin router and modems
i would suggest returning the router and/or purchase a modem router, as it does away with all the connection problems and the need to click dial to connect as a modem router is always on and does not require a main pc to be on. It will also probably be cheaper than buying a seperate modem.
Sep 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Compaq Presario 700 470024-192 Notebook Logo
66 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
