Question about Memorex MT1134 13" TV
Analog VCR I have an analog TV and subscribe to cable TV, so I know my TV will be fine once the Big Switch happens. But my VCR is analog, too, and I can't get a positive answer from anyone when I ask if I'll be able to use the analog VCR (which is hooked up to my analog TV) when the Big Switch occurs. Do I need to get a new VCR with a built-in digital tuner or will a converter box hooked up to my VCR enable it to work (record, playback, etc.) as I'm used to doing? I'd like to know, too, if I'll still be able to watch one channel while recording a show on a different channel. In advance, thanks.
  • 537 Answers
No you can use your regular VCR. You will just have to make sure you put your coverter box to bring the signal into your vcr. You can also bring the signal into your TV from the vcr so that you don't have to have 2 converter boxes.
Posted on Jan 23, 2009
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Analog or dtv
Hi, This tv has an NSTC tuner which is analog. If you subscribe to cable or satellite it will work just fine without you having to do anything for the upcoming change. However if you are using your own outside antenna or rabbit ears you will need a converter. Hope this helps.
Jan 30, 2009 | Philips 20PT6446 20" TV
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Memorex MT1134 13" TV Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
