I never Used A Fax Machine. I was Given A ''Brother IntelliFaxMC''
How Do I Fax Documents Out To Someone? Which Way Do I Turn The Paper etc.?
    Scholar:
  • 75 Answers
If you look at the area where you put your paper to seend ( that is the document feeder ) there should be a diagram of a pice of paper with a corner turned over, if lines are on the top part put paper in dac feeder face up. if lines are on the little corner pice put the paper face down,
if not sher put one pice of paper with lettering in doc feeder press copie of it comes out you got it right. hope this helps
C.W.H. ( typboy)
Posted on Jan 23, 2009
When faxing documents on a Brother 525 fax machine do you put the item Face up or face down
If you have a Brother FAX-525DT, then place the document face down with the leading edge (top) down. The scan unit is on the bottom of the paper path for documents. The manual for the unit is available from Brother's EU division's support. The direct link is http://www.brother.com/pub/eur_fax_doc/fax515_525dt.pdf . The picture for how to position the document to be faxed is on page 55 (page 65 of the PDF).
I hope this helps.
Jan 27, 2016 | Brother Office Equipment & Supplies
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Does the Brother Fax2920 store sent documents.
    Turning off Remote Fax
    Options
    1 Press Menu/Set, 2, 5, 1.
    2 Press ▲ or ▼ to select Off.
    Press Menu/Set.
    3 Press Stop/Exit.
    If after doing this, you may get a message "Erase all fax?" with 2 options, 1.YES 2. NO
    Simply select YES to erase all Fax stored in memory.
    I do hope this fully answers your fax question. Take care!
    Greg
    May 22, 2009 | Brother FAX-2920 Plain Paper Laser
    May the tellifax be used for copying only?
    http://www.brother-usa.com/manuals/default.aspx?ModelID=455&ProductGroupID=2
    This is the link to the manual, and yes you can make a copy, put your original in as you would to send a Fax, but press the copy button, and then the start.
    Hope this helps
    Ed
    Apr 14, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
    Brother fax machine Fax-2820 MFC-7225N
    Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
    May 08, 2008 | Brother IntelliFax-2820 Laser Fax
    Prints with a white line vertically down the page. How can I fix this?
    Apr 25, 2008 | Brother IntelliFax-2820 Laser Fax
    How to change the receiving tray for faxes?
    Look around for a small lever or lock that you adjust for one way or the other. open the top front and look to the left. it might be there.
    Feb 12, 2008 | Canon FAX-L200 Plain Paper Laser
    69 people viewed this question
    k24674
    jasbo
    jasbo
