Question about Mercury KVM800M Motherboard
Sata Hard disk and DDR 1Gb Ram not supporting to my motherboard how can i add and detects this both things please give me reply as soon as possible
  • tabrezsd2003 Jan 23, 2009
    i have dgnet 1gb ram pc400nhz 05 01091211 still having problem i change 3 to 5 rams same problem blue screen less_equal
    Problem Solver:
  • 14 Answers
Do you have a SATA Cable for your SATA hard disk?
What are the spec's for your RAM, it should be 2 x 184 pin DMMs, 400 MHz, 333 MHz,266 MHz memory. up to 2 GB Ram.
Posted on Jan 23, 2009
Hi i have 1gb ram and 160gb hard disk in intel d945gccr . my question is how much supported ram and hard disk in intel d945gccr. reply soon thanks
This motherboard of yours can support up to 2GB of RAM and for hard drive you can use here 500GB and for the complete details abut this motherboard you can got o this link , just click HERE.
Jan 19, 2011 | Intel D945GCCR Motherboard
Supported RAM AND HARDDISK for INTEL D915GLVG MOTHERBOARD
Intel D915GLVG Supports
Memory
  • DDR - 400 & 333 MHz
  • Serial Presence Detect (SPD)
  • Unbuffered, non-ECC RAM (registered memory is not supported)
  • Up to 4 GB
  • 4 slots(1GB MAX EACH)
Hard Drives
  • Four Serial ATA (SATA Drives of any capacity are supported (e.g. 250/320GB)
  • One IDE interface
For further information, you may refer to the Intel official product details at the following link: -
http://www.intel.com/support/motherboards/desktop/d915glvg/sb/CS-020821.htm
Hope it Helps!
CreativeTECH
Nov 22, 2010 | Intel D915GLVG Motherboard
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
My motherboard currently has 2 512mb sitcks of ddr ram. if i try and add anymore ram my system will give me beeps and not boot. ive tried adding a matching pair of 256mb sticks of ddr to my existing...
means ur board only support max 1gb ram can u give me detail of ur system means details of processor,motherboard etc.... write it on a testimonial ill definately let u know
Jun 16, 2010 | Chaintech S1689 Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
How much Hard disk my motherboard D845GVSR will support.
There's not really a limit to how big a harddisk you can support. The only thing that can restrict you is the connection, because, for obvious reasons, you can't connect a SATA disk to an old IDE board, but it seems like you're aware of that.
You can just buy any SATA HDD you want!
May 13, 2009 | Intel D845GVSR Motherboard
Compatiblity issue..
You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
This is from your manual:
Dual-channel DDR400 memory support
Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
If you would care for the manual, here is a link:
Asus P5P800-VM Manual
Thanks for using Fixya.
Apr 03, 2009 | ASUS P5P800-VM Motherboard
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Hard disk and ram size
Here's a quote from a site which sells that board.
The D915GAGL provides 4 DIMM sockets using 184-pin DDR with a total capacity of up to 4GB. You can install DDR PC3200/2700 memory modules.
I see yours isn't an AGL, but if you open up your case and see that there're four slots for ram, then it should have the same limit.
What this means is, each slot can handle a max of 1GB per stick. So 4 sticks is for GB's.
As for hard drive size, this is usually a limit of the OS and not really a problem since earlier windows days. You should be able to put a fairly large hard drive in there, just make sure the right cables are used. This board uses SATA cables, so your hard drive must be SATA not PATA.
Hope this helps.
Caid.
Dec 29, 2008 | Intel D915GAG Socket 775 Motherboard -...
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Dec 16, 2008 | ASUS A8N-VM Motherboard
Mercury KVM800M Motherboard Logo
167 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
