Question about Sharper Image Ionic Breeze GP SI720 Air Purifier
What does a blinking blue light indicate?
When the power switch is in "ON" or "ON/G.P." the respective blue indicater blink on/off
  • cyko_md Dec 06, 2007
    I am having a similar issue but... The High light is blinking and there is NO light highighted when switched to On or On/GP. The UV light is ON though. No matter what position the knob is set to, Low, Med, or High the blue light above it blinks and the On button does not turn on. I have throuroughly cleaned the unit and the blades, I usually clean the blades once a week and the unit about ever month. It still seems to be working and isnt making any noise but it still worries me.
    Novelist:
  • 135 Answers
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Posted on Aug 05, 2007
I to have had the problem with the blinking light and could not get it to stop.
I am a very persistent person. I took my unit apart and located the wire that one person indicated is the problem. It look to be the equivalent of brain surgery to work on this wire so i just cleaned the unit very well using a wet cloth and a clean paint brush to dust other areas inside. This was probably good but when I put the front and rear grilles back on and plugged it in the light still blinked.
I decided to find a reset by unplugging the unit and holding down the "boost" button. I tried several scenarios and unfortunately cannot tell you exactly what combination worked because the blinking light problem no longer exists to go through steps to determine which combination worked. What I can tell you is that it was simple. Unplug the unit, hold down the boost and plug it in while continuing to hold it down. After 2-3 seconds release it. Now if this does not work for you try the same with the knobs left knob turned off or on another setting. It will not take long to find the combination if you follow , unplug, hold down button, try different knob position method. I wish you luck.
Best regards,
Kirk Wiggins
Posted on Aug 09, 2009
I fixed the problem by getting a power supply (the part that plugs into the wall socket) that has a higher amp rating. the plug that came with mine was rated for 12 volts and 500 mA and i replaced it with a 12 volt 1000mA (or 1A) and it now works better on low than it did on high before. however it still has the blinking blue light on high. so far it works!
Posted on Jul 15, 2008
SOURCE:
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 19, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
The blue light blinks
I believe that a blue blinking light indicates that the stainless steel collection blades need to be wiped clean. The unit uses these blades instead of a replaceable filter. Simply wipe them clean with a damp cloth and you should be ready to go!
Jun 24, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Flashing blue lights
toss it. learn from it. Use Consumer Guide or something similar. Thank god it fots down the incinerator duct.
Jul 28, 2009 | Sharper Image Professional Plus Ionic...
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! [email protected]
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
Blinking blue lights on top
OK so after a bit of investigating there is still HOPE!
There are no details about the blinking light except that the unit is "broken". Mine appears to still be somewhat functioning as I smell ionized air.
As you all know, Sharper Image is Bankrupt and their stores have all closed. Here's where the ray of sunshine comes in:
If you purchased the extended warranty all you have to do is call 1-866-686-2463 24 Hours 7 days a week. The gentleman who helped me confirmed the information on my original receipt so there must be some database I am registered under. I will be receiving a replacement within a week.
I will take mine apart to see if I can repair the broken unit and if I find out the problem I will post up.
Here is something for you to try...Unplug the unit and plug it back in while holding down the boost button. This seems to trigger some form of diagnostic. On Low the clean light is red and then amber in the other positions. The boost button flashes. It may do something different for you that is why I bring this up.
Dec 12, 2007 | Sharper Image (SI871 GP) Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Sharper Image Ionic Breeze GP SI720 Air Purifier Logo
3,000 people viewed this question
Top Sharper Image Air Purifiers Experts
Ekse
Marvin
Marvin
Jason
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
