Pool & Spa Logo
A
Anonymous Posted on Jan 13, 2013
What are the F numbers 2,4,6,8 on the display
HP 12 C display does not show entire numbers. How do I fix?
If you mean it is not showing everything after the decimal point, you can change that by pressing the [f] key followed by the number of decimal places to display. For example, to restrict it to 2 places, press [f][2]. If you want to see 4 places, press [f][4].
To show all possible decimal places, use the sequence [f][9].
From the manual (http://www.hp.com/ctg/Manual/c00363319.pdf):
"To display a different number of decimal places, press f followed by a digit key (0 through 9) specifying the number of decimal places. In the following examples, notice how the displayed form of the number inside the calculator - 14.87456320 - is rounded to the specified number of digits."
25096057-rvrejqbjq4zuw4cbinsyjvsy-5-0.png "Although nine decimal places were
specified after f, only eight are
displayed since the display can
show a total of only 10 digits. "
The standard display format, plus the specified number of decimal places, remain in effect until you change them; they are not reset each time the calculator is turned on. However, if Continuous Memory is reset, when the calculator is next turned on numbers will be displayed in the standard display format with two decimal places
shown.
If a calculated answer is either too small or too large to be displayed in the standard display format, the display format automatically switches to scientific notation. The display returns to the standard display format for all numbers that can be displayed in that format.
1helpful
3answers
How do i reprogram my speeddial numbers on jazz 4400?
Although I've been unable to locate a User Manual specific to your phone, the following information pertains to programming most all NorStar phones:
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
To Change the Contrast of the Display:
1. Dial the Feature button, then * 7
2. Press the number keys 1 - 9 to your desired brightness level
3. Press the OK softkey
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 - 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.)
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94. that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
Additional information about NorStar phones can be found by clicking here:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Need a code to unlock my radio for a 97 grand prix
Follow these steps to unlock your GM Delco Radio:
1. Turn the ignition ON (The Delco radio displays "LOC" or "INOP").
A. If your radio says "INOP" then you have entered too many wrong codes. You will need to run the vehicle for one hour or turn the key into the ON position for one hour before you can proceed to Step 2.
2. Looking at the face of your GM Delco radio, hold down the preset buttons 1&4 or 2&3 for approximately 10 seconds. The radio display changes from "LOC" to a three-digit number. Write this number down.
3. Press the AM/FM button. The radio display changes to another three-digit number. Write this number to the right of the first one.
4. You now have a six-digit number, the first three digits are from STEP 2 and the last three digits are from STEP 3, you will have a number like this (612-622).
A. NOTE: Saturn and GEO vehicles will only display a four-digit number. The fourth digit will be displayed half the size of the first three digits. Example: 2193.
Hope helps (remember rated and comment this).
3helpful
I have an 1998 audi a6, the radio is in safe mode. I red the other responses to the solution to this problem but how long do you have to hold the SCAN and RDS buttons? I held them for about 2 minutes but...
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display. Release buttons. Do not, under any circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code. Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number. Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display. Release buttons. Soon afterwards a frequency will be displayed.
For a 1998 Audi Quattro with a Delta radio, the button combination is DX and FM1/2.
5helpful
2answers
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
1helpful
I WAS RE-PROGRAMMING MY AUTO DIAL BUTTONS AND WAS ON MY 3RD ONE WEHN IT DECIDED THAT ALL MY BUTTONS WOULD NOW DIAL THAT NUMBER. i CAN'T TOUCH A SINGLE BUTTON WITHOUT IT DIALING THAT NUMBER.
For Feature Codes:
Baud rate
Please follow the steps given below to reduce the baud rate on your printer.
1. Turn on the HP all-in-one.
2. From the keypad, press * and # keys simultaneously.
3. Press 1, press 2, and then press 3. Service followed by a number will be displayed on the front panel.
4. Press the right-arrow to select System Configuration.
5. Press Enter on the front panel.
6. Press the right-arrow to select R/W Parameter.
7. Press Enter. Parameter 0 will be displayed on the front panel.
8. Press 1, press 5,press 1 (i.e,151) and then press Enter. The display should read Value followed by a number (example, Value 60).
9. Press 2, press 6, and then press Enter. This will display Parameter 0 on the display.
10. Press 1, press 5,press 3 (i.e,153) and then press Enter. The display should read Value followed by a number (example, Value 60).
11. Press 0, and then press Enter. This will display
12. Press Cancel repeatedly, until the display reads the date and time.
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
Radio lock
1. Turn the ignition ON (The radio displays "LOC").
2. Press and hold presets buttons 2 & 3 or 1 & 4 for approximately 10 seconds.
The radio display changes from "LOC" to a three-digit number. Write this number down. If you have a Saturn or GEO, see note below and skip to step 5.
Don’t take long, fifteen seconds max before the next step
4. You now have a six-digit number, the first three digits are from STEP 2 and the last three digits are from STEP 3, so you will have a number like this ( 212 - 212 )
DO THIS AND GIVE ME THE CODE YOU GET AND I WILL GET U UNLOCK CODE
Top Balboa Instruments Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
