Question about Frigidaire ATF6000ES Front Load Washer
Rubber seal spring has let go
Hello
I have a Frigidaire front end loader washer that was banging out of control during spin cycle, I noticed the seal seemed to have slipped off the drum and the spring holding the seal had come out of the seal groove. I noticed a buildup of soap residue on the seal which could have caused this to happen, lubricating the seal and causing it to slip off. Question is how do I put the spring back over the seal on the drum? I have cleaned off the residue.
    Top Expert:
  • Frigidaire Master
  • 67,911 Answers
U are going to have to replace the seal, the spring is build into the seal and if it comes out the seal is shot.
Posted on Jan 23, 2009
I have a frigidaire affinity front loader washer that the final spin cycle won't work on. The rest of the wash cycle is fine and the basket spins for the other cycles just not the spin cycle. It is also...
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Jul 13, 2010 | Frigidaire ATF6000ES Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Banging and small leaking
Is this a front loader you have? the banging could be broken shocks.
Mar 11, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Feb 03, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore 44832200 banging during spin cycle
The support spring beside the spinning hausing are cut replace w/new spring available appliances store. bring sample.
Jan 07, 2008 | Kenmore 44832 Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
195 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
