Question about GE FUF14SVRWW Upright Freezer
Fuf14svrww door open alarm on - GE FUF14SVRWW Upright Freezer
Are "door open" alarm won't stop beeping.
Try disconnecting the power at its source, then reconnecting it.
May 17, 2015 | GE FUF14SVRWW Upright Freezer
What does fault code mean?
Look in the owners manual for trouble codes
Nov 02, 2014 | GE FUF14SVRWW White 13.7 Cu. Ft....
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
My GE FUF14SVRWW upright freezer will shut off for no reason. The digital temperature control will be blank, the light will not turn on, and freezer isn't running. I will unplug it for a few minutes and...
Ach, digital controls! It sounds like the logic board/panel is on the fritz. No cure unless you can identify the malfunctioning component and replace it.
Nov 05, 2013 | GE FUF14SVRWW Upright Freezer
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
Control shows door is open on ge freezer FUF14SVRWW but it is not
Check to make sure it closes evenly all around. There should be an adjustment bolt on the underside of the door.
Sep 27, 2013 | GE 13.7 Cu. Ft. Frost-Free Upright Freezer...
The "door ajar" alarm keeps going off and the door is sealed shut?
Your door switch may be bad. Is the light on when you open the door when you manually push in on the switch does the light go off? On most fzr the door ajar alarm is set off by the door switch showing the door is open.Turn off the power by unplugging the fzr then you can pop the switch out with a flat blade screw driver if it is only a two wire you can use a paper clip to connect the two wires wrap them with elect tape Then plug the freezer back in and see if the problem clears if it does order a door switch. Some units use a vacume sensor but i believe all kenmores use the door switch. good luck
Aug 17, 2010 | Kenmore Freezers
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
Nov 12, 2009 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
GE FUF14SVRWW Upright Freezer Logo
Top GE Freezers Experts
christian nielsen
John Tripp
John Tripp
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
