Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Lock light flashes
Pressing cancel light and lock light and cancel light flashes together
  • 537 Answers
Check this FixYa link:
http://www.fixya.com/support/t138411-control_lock_light_remains
Posted on Jan 23, 2009
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
"Locked Door" flashes after interrupting self clean...
Hi robertkbrown...you may want to try to following steps.....good luck my friend...chris If ?LOC DOOR? is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control: Motorized Switch 1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel. 2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed. 3. While you hold the door jamb switch in this position, complete the following steps. 4. Press the Clean pad, wait 10 seconds. 5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it. 6. Wait 10 seconds for the display to clear. 7. The door should unlock and there should not be a need for service. Manual Switch 1. Press the Clean pad. 2. Close the door. 3. Slide the latch to lock the door. 4. Hit the cancel button immediately. 5. Unlock the door.
Aug 25, 2007 | GE JBP60 Electric Kitchen Range
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Lock on light flashing. Dishwasher will not do
Hi
This is a child lock feature to stop unwanted operation of the buttons. The usual way to cancel this on a Kenmore machine is to press and hold the "No heat dry" button for longer than 4 seconds. This should cancel the lock and resume normal function.
Hope this helps. Please do rate this answer. Thanks.
Aug 16, 2009 | Kenmore Dishwashers
Lock light stays on
It sounds like the circuit bontrol board is cracked or shorted, which means it must be replaced.
Jul 24, 2009 | Kenmore 15762 Dishwasher
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
"Locked Door" flashes after interrupting self clean (follow up)
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
107 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
