Question about ViewSonic Computers & Internet
Need a driver for vg1921wm-2 monitor model vs11354
Windows XP driver is needed for downloading and reinstalling.
  • 76 Answers
SOURCE: need to reinstall my monitor to my pc
What does this software do that you need? Monitors do come with software but I've only very very very rarely ever installed it. Most of it are color styles or software to effect color changes under special user scenarios. This monitor is sold in Walmart and I tried to get the software for it but failed. Simply hooking up the monitor "installs" it to your PC as Windows is aware of "plug and play" monitors. All you really have left to do is change to a suitable resolution using the Windows control panel. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 22, 2007
  • 44 Answers
SOURCE: Viewsonic monitor not detected after service
If you are running DVI-D(the white connector) then it isn't getting a digital handshake. If you have inspected the connection between the 2 and make sure there is no bent pins inside the connector that it mates with. If you have another computer, try to connect to that one.
Open windows start menu, right click on my computer, then choose properties. Next choose Hardware, then Device manager. Once there, double click on display adapters to see if installed correctly. If good, click Monitors. If good, then your video card driver must need reinstall or update as usual. Also do you have the correct driver for you monitor? How does it react when you uninstall the monitor driver(can you select 32bit and higher resolution in default drivers?
If none of this works, I would suspect that the replaced component failed due to static or faulty components within the electronics.
Is there any other changes to the PC (new video card, updated Directx9.0?)
Hope this helps and let me know if I can be of anymore assistance?
Posted on Aug 20, 2008
  • 9 Answers
SOURCE: slow scrolling and pages overlapping.
You need the appropriate drivers for your graphics card. The problem is not the monitor. It is that the window default driver for your graphics card is not driving the card to it's full potential, therefore screen updates are much slower than they could be with the drivers that suit your card..
cheers,
dave.
Posted on Nov 29, 2008
sys_admin
  • 829 Answers
SOURCE: I need the driver for the Belinea LCD 17" monitor model 10 17 15
Hi ,Download from the below link
http://driverguide.com
Posted on Jan 11, 2009
florin_decad
  • 203 Answers
SOURCE: Monitor Drivers for Hannspree 199H
go to manufactor website and download all the driver's or use DRIVER MAX to find your driver's
Posted on Jan 17, 2009
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
After reinstalling Windows XP, my PC can't detect
Yes you need to install the ethernet driver . You can download it here. You can either enter your service tag number which can be found on the back of your CPU or you can manually select the model. Once done, it will display all the available drivers for your device. Make sure you choose the right Operating System and download/save the ethernet driver you need. Install it ands reboot the computer. Once the right driver has been installed, your computer should be able to detect your modem again.
Hope this helps.
May 31, 2011 | Dell Computers & Internet
Whenever I reinstall my Windows XP Pro, I'm not able to adjust the settings. I only get 640x480 and 4 colors. I'v e tried installing the drivers to no avail. Had the same problem 2 yrs ago but can't...
You need to download and install the correct driver for your video card, right now the driver is the microsoft generic video driver that it is using. Go to your computer manufacturer/mother maker web site to download the correct drivers.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 31, 2010 | Acer AL1716 17" LCD Monitor
ViewSonic VG1921wm no picture
You will need to open it up and inspect the inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | ViewSonic VG1921wm 19" Monitor
Cant get internet access on my asus after reinstalling of Windows xp - which drivers to I need to get this access??
you should go to the asus website and download all drivers for your model number. yes, you will need to gain internet access from another computer.
Dec 28, 2009 | Microsoft Windows XP Professional With...
Can you help me install my dell 720 printer with the drivers download from dell? My 720 dell printer installation disk was lost and I have had NO success reinstalling the printer with the drivers download...
you can follow these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
12. Make sure the driver you downloaded from support.dell.com is compatible with the operating system that you're using, for example windows xp or windows vista.
Oct 01, 2009 | Dell Inkjet 720 Printer
Compaq presario c 700 laptop driver free download
dear sir,i got a problem which led me to format my system, After formatting, I reinstall the Windows [xp sp,2] i need to download all drivers,pleas help me. Thank You
Feb 04, 2009 | Compaq Presario 700 470024-192 Notebook
I had to reinstall Windows XP-Pro and am in the process of reinstalling drivers for all my stuff. I can't find the disk for my KOGi monitor and am looking for one on the internet. It is Model L7EM-TA....
Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 23, 2009 | Kogi L7CH Monitor
Re No sound from monitor speakers
Thanks for the info,
Ok heres what I would doo to fix this.....
Get the original disk with the drivers on it and reinstall it.
If you don't have the disk then you will have to ......
(unplug sound card - if its a plug in)
Remove the cables,check for model and make,download from net.
or
if sound on motherboard then download the model and make also.
You will have to load the downloaded drivers on to a disk.
2.update your device drivers and point the wizard at the disk,
Reboot and that should be it sorted,
Thanks and let me know the outcome,Cheers
try this site.....
http://www.opendrivers.com/driver/211081/sound-blaster-audigy-driver-5.12.4.252-windows-98se-2000-xp-free-download.html
Jul 24, 2008 | HP Compaq WF1907 Monitor
My monitor is stuck in the lowest resolution
Distorted video after increasing the resolution in Windows. The resolution has been set higher than what is supported by the monitor, ... we recommend 640 x 480 with 256 colors or the lowest available setting.
Computer always boots into Windows safe mode. When booting into safe mode, the lowest settings are used, including your video card. This means that the resolution is 640x480, 16 colors when in safe mode.
Drivers & Downloads for your Dell Monitor Drivers & Downloads for your Dell Monitor ... Drivers & Downloads for your Dell Monitor
These's site click on them and follow instructions, Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
47 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
