Question about Skytech 3301-BE Gray Five Button Thermostatic and Programmable Wireless Fireplace Control System with Battery Eliminator 3301-BE
Princeton gas fireplace is beeping - Skytech 3301-BE Gray Five Button Thermostatic and Programmable Wireless Fireplace Control System with Battery Eliminator 3301-BE
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 | Dishwashers
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Gas ventless fireplace remote will not work have inserted new batteries in both fireplace and remote but fireplace not recognizing remote
Every time the batteries are changed in the receiver and transmitter the transmitter has to be "re-learned" to the receiver. To do this locate the "learn" button which will look like a tiny hole so you have to stick the end of a pin or a pen in the hole to press the button. Hold the button down until it beeps at you 5 times and release. press the button again and release and then press Any button on the transmitter.
Once the receiver is set into its "learn" function it does not matter what button is pressed on the transmitter because the next signal the receiver picks up will be the frequency it is attached-to.
In order to change the transmitter simply hold the learn button down until it beeps 5 times again which tells us it has wiped out its memory. Then press, release and press the transmitter.
Nov 20, 2014 | Real Fyre 24" Forest Oak Ventless Natural...
Gas fireplace remote wont turn on the fireplace new batteries have been inserted with no result
If you want to check if your remote is working and you have a cell phone that takes pictures hold the remote in front of the camera and when you have a pitre of the remote press the button and you see it on the camera if you don't the remote is not working hope this helps (this goes for all remotes ) Tom
My remote is beeping on my gas fireplace model Vff-PH32DR
Check the batteries. in the receiver and remote.
Jan 23, 2014 | Pleasant Hearth Home
My dimplex electric fireplace model HEF22 wouldn't turn on
take out fireplace flame, 4 screws, in the middle is a thin sq. black box 1.5 inchs sq. with an insulated screw driver pull it forward. you should here beep,
if u do- unplug-get a good tape,put tape to keep it forward, what happens is it pulled backwards and the two pins slipped out of the circuit board. dust while u arre in there. hope that works for u. mine is working.keep fingers ccrossed. HAPPY HOLIDAYS
Apr 10, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
Receiver was beeping all the time. I changed batteries in receiver, and now remote does not control fireplace. Remote appears to be working fine. If I move switch to on instead of remote on receiver, it...
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Feb 03, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Receiver was beeping... Jiggled it ... Stopped beeping... Now not working ...tried to reset transmitter with receiver but will not work .... Did replace batteries and recharged receiver as well ... Remote...
There's no quick answer to your problem, as it may be your gas fireplace that's causing the problem. If you still have your Owners Installation Manual look at page # 7 (Trouble Shooting), this should help you solve your problem. If you don't have your Owners Manual, you can download it online from SkyTech's website. If all else fails contact SkyTech's Technical Service Dept @ 888-672-8929
They are friendly and knowledgeable folks to work with.
Jan 11, 2011 | Skytech 3301-BE Gray Five Button...
My remote won't control the fireplace. Do you have to program it
Normally, it comes programed. Before trying to reprogram it ...First, be sure you have the leads from the black receiver box connected to the proper terminals on the control valve of your gas fireplace. Secondly, be sure ALL the batteries are installed properly (i.e. facing the right direction). Do you get a beep when you press the Mode button on the hand held remote? If you do, the problem is some where else.
If you gas fireplace has a rocker switch in the control compartment that was used to turn the burner on and off ... Is it a 2 position switch or a 3 position switch? If it's a 2 position switch, be sure it's in the ON position. If it's a 3 position switch, it should be in the middle position. Is the gas control valve knob turned from Pilot to the ON position? Is your Pilot Light burning? It has to be for the remote control to work.
To test the whether or not the remote is connected properly, push the slide switch on the front of the black receiver box to the ON position. If you pilot is burning and the control knob for the burner is in the ON position, the burner should then light. If it doesn't then I suspect the wiring from the black receiver box to the control valve is not connected to the proper terminals. Or a rocker switch is in the wrong position. If all this fails contact SkyTech Technical Service @ 888-672-8929.
Jan 10, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech 3301-BE Gray Five Button Thermostatic and Programmable Wireless Fireplace Control System with Battery Eliminator 3301-BE Logo
22 people viewed this question
Top Skytech Home Security Experts
Lawrence Oravetz
Are you a Skytech Home Security Expert? Answer questions, earn points and help others
